Results 1 to 20 of 20
    Jun 2011
    Haverstraw, New York
    16
    LiPo Voltage Question
    Hi, I opened a thread about a puffed battery. Tonight I am buying a new one and now changing some of the ways that I used on the old LiPo. Since I have learned the hard way to not store a battery at full charge, and don't own a multimeter, how can I store my LiPos when not using it. Should I run the battery near LVC and store it or should I balance it just a little bit before? Any replies will be appreciated.
    Buffalo NY
    1,330
    Do you have a charger with storage mode? Storage mode charges or discharges your pack until it reaches 3.8v PER CELL.
    Jun 2011
    16
    I have a Passport LiPo, so no I do not.
    Buffalo NY
    1,330
    I've been learning a lot about storage mode from Jimmie Neutron, et. al. It's supposed to be beneficial when you're not using your batteries for a few days or longer...that's why I mention it. Now between you, me, and the entire forum , I have not used storage mode in the past and have never had a problem with my LiPos. The most important things to remember:
    1. Don't leave 'em sit with a full charge (as you've learned ,
    2. Don't overcharge -- 4.2v max per cell!
    3. Don't over DIScharge 3.5v minimum per cell,
    4. Always balance charge,
    5. Use a LiPo charging sack or Battery Bunker,
    6. Check each pack's individual cells with a cell checker (Dynamite makes one, sold at A-Main Hobbies).
    Zeeland Michigan
    1,194
    Quote Originally Posted by iaustin7 View Post
    Buy yourself a LVD with buzzer off ebay for less then $10. I use one with a auto bulb light a 1175 bulb for discharging .
    1 Rusty VXL
    Zeeland Michigan
    1,194
    Storage is 3.85 per cell .
    1 Rusty VXL
    Jun 2011
    16
    Just went to the shop and got a 2S LiPo 5000mAh and a large charging bag. Thanks everyone for your replies!
    Alma, MI
    12,279
    Quote Originally Posted by zippogeek View Post
    Minimum is 3.0v/cell... not 3.5...
    Well... actually it is 2.5 as an absolute do not go there... that is why 3.0 is the low.
    But... do not set a LVA that low if you have a choice... 3.3 or higher, please.
    Norfolk, va
    1,167
    I have 2 alarms and the meter.
    http://www.amazon.com/Bluecell-Digit...rds=Lipo+alarm
    This is a good deal since you get an alarm and a meter for $2 more than one or the other. Alarm can be used as a meter but it is noisy when you plug it in.
    I usually drive my cars till they get to storage voltage or charge them up to storage voltage.
    3.7-3.8 is where I put them.
    ERBE, ERBE, Summit, Slash 4X4, Bandit,
    86
    I'm a truck driver and I'm only home on weekends. What I do with my batteries is. My charger has a storage setting. It will bring each of my cells to 3.8volts. If they are under that volt it will bring it up. If they are over it will bring it down. If your charger does not have that setting just charger or discharge them till they reach 3.8 each cell. I've been doing it to all my batteries since news and they work great.
    Oct 2012
    540
    When you storage charge a battery, do you charge it at the normal amps on Storage Charge or is there a special calculation for charging on storage mode? I usually charge my 2s 8200mah lipo at 8.2 Amps, so would I do the same except on storage mode?
    Dirt Slingerz Racing
    Slash VXL - Summit
    Alma, MI
    12,279
    No special calculation... set for normal amps.
    Oct 2012
    540
    OK. Thanks Jimmie
    Slash VXL - Summit
    Buffalo NY
    1,330
    Thanks Jimmie.
    Oct 2012
    540
    If I am right, a 2S lipo has 2 cells? I am looking at the cell voltage on my one battery that is storage charging at 8.2 amps like I would normally charge it. The cell voltage count for the 2 cells is currently 3.86. Is that to much or is it going to be around that number?
    Slash VXL - Summit
    Alma, MI
    12,279
    A 2S LiPo as at least 2 cells... they can have more.
    Are you sure you have the pack connected properly?
    If the pack voltage is that low, the pack is ruined.
    If you press the right arrow on your 206B, it will tell you the cell voltages.
    Oct 2012
    540
    The pack voltage says 7.81 but the charger just beeped off and it says 3.85 per cell and the pack voltage is 7.65
    Slash VXL - Summit
    Alma, MI
    12,279
    What are the cell voltages when you press the right arrow?
    Buffalo NY
    1,330
    Quote Originally Posted by Jacob Chandler View Post
    Correct, 2S = 2 cells.
    When fully charged, a single 3.7v LiPo cell should actually have 4.2v max; 3.7v is just the nominal. So a 2S pack will have 8.4v max...not 7.4
    Oct 2012
    540
    Cell voltages are 3.82.
    Slash VXL - Summit
