Results 1 to 18 of 18
Thread: Bad body roll
    12
    Bad body roll
    Guys, I changed my springs to black in front and tan in the rear as recommended here on this forum and while it help greatly with dive and squat, I still feel the body roll / leaning is still pretty bad (mustang Vxl). How else can I improve handling and keep it flatter in turns? Will the HR sway bar upgrade help with this? What about a shorter travel rocker? Any tips fellas? Thanks in advance.
    12,290
    What weight of oil are you running?
    12
    Stock right now.
    12,290
    Are you sure they are full?
    12
    Hi Jimmie, yep I checked them. They are full and no air bubbles. I mean these things do not exactly handle well to begin with, I understand that, just trying to minimize or lessen the body roll because its still pretty bad. I'm sorta new at suspension tuning, etc. Will using a heavier weight oil help with this?
    12,290
    Heavier weight will help quite a bit... so will sway bars. P1 rockers should too, but they are not made for this platform.
    FarNorCal
    273
    I did the black/tan springs too.....but up'd the oil to 70 wt and it's fantastic!!!
    rc10T3, TT Sparrowhawk XXB, Slash 4x4, 1/16 Rally
    Covina, So Cal
    638
    I went up on the shock oil weight, and stiffer springs, AND installed the HR sway bar kit. Minimal dive, still has some squat (weight transfer) in the rear upon acceleration, and MINIMAL body roll. The sway bar kit has 3 different wire thicknesses, and is adjustable.
    AB
    12
    thanks guys. I'll try heavier weight oil first. Then may do the HR sway bar kit. Thanks!
    Apr 2010
    windsor ct
    71
    FarNorCal
    273
    Toadzrc is awesome!!! Great people and fantastic service!!!! (and local for me )
    Jul 2013
    77
    did you limit the amount of droop in you suspension i had the same issue in corners with some washers to limit the droop the shocks can travel will help out
    35
    Does your car go straight on wide open throttle? Mine goes nuts to the passenger side I check and all 4 wheels look aligned pretty good
    Jul 2013
    77
    i had to readjust my settings to go straight and i think centering you servo horn/arm will help.
    Jul 2013
    77
    Heres some more info and video of what you can do on road. If you havent solved your body roll issue yet.
    Heres a video i found to inspire getting my setup. Where i found my set up: http://www.rctech.net/forum/micro-mi...ly-car-36.html
    http://youtu.be/WBAaXaLtiQU
    in my opinion this is how Traxxas should have set up the Mustang boss/fiesta. it be easy to get a drift and and high speed set up without traction rolling every corner when stock.
    la porte
    689
    Bad body roll
    That's my local track mikes in porter it's an onroad and offroad track we are holding roar nats again this year.
    Here's a link to our local forum with with the setup used in the vid
    http://www.rcfiles.com/forums/showthread.php?t=31191
    Sent from my iPhone using My Thumbs
    Jul 2013
    77
    Quote Originally Posted by mydudrevo View Post
    Looks like one awesome track to race and the racers as well.
    la porte
    689
    You should see the offroad track. It's awesome. I don't race onroad but I want to get a 1/16 to run between offroad qualifiers.
