Results 1 to 12 of 12
    31
    Really 5 hours + of balancing
    Any clues as to y. 11.1v 5000 mah traxxas 3s
    Buffalo NY
    1,330
    What charger are you using?
    31
    Thunder ac680 its never taken over a hour ......did I forget to mention its still balancing!!!!!!!!
    Why why why especially since I balance after every charge and once a week give it a slow balance at 2amps instead if 5
    12,290
    What are the cell voltages?
    Norfolk, va
    1,167
    If the cells are 4.18-4.20 just take it off the charger and use the battery.
    31
    Finally done 5 hrs 24 mins.. 4.21, 4.20, 4.20
    Norfolk, va
    1,167
    My chargers have time limits and mah cutoffs. 120 minutes it will hit the time limit(default setting) and it will say current limit if it puts in the mah you chose before hitting the 4.2v limit.
    31
    Mine has same timer I just kept restarting till it completed it
    Buffalo NY
    1,330
    I guess my question is, why would a "smart" charger do this?
    31
    Quote Originally Posted by zippogeek View Post
    Good question
    friendswood texas
    1,350
    I use 2 traxxas EZ peak Plus. Last time I went to store my lipo it took forever. It was close but the charger would not finish. Switched battery to other charger and it stopped at storage in 2 minutes. I haven't had a problem since just my experience. Maybe a charger glitch? Yes I plug in the balance board for every charge and storage.
    12,290
    Because the cells are out of balance... the charger has to bleed off the voltage from the higher cells and feed the lower cells to get them to match. The further they are out, the longer it takes. The lower the capabilities of the charger, the longer it takes.
