http://www.ebay.com.au/itm/Steel-Con...#ht_500wt_1156
1. It says E-Revo but i want to know if they'd fit in a summit?
2. Will they be stronger than stock or equal strength?
Green.. Green is nice
Sorry I can't answer your first question, but someone will surely know.
2. I believe it is stronger than stock. I am running the steel driveshafts in the centre (trans to diffs) and they have held up well.
If you find these fit the summit then go ahead but leave the stock plastic driveshafts in the centre. Your driveline has to "give" somewhere.
In my case i have the steel centres so i am keeping the stock plastic axles.
If the summit can go through; its not deep enough
Yes they are stronger than stock, but a hard impact would still bend them out of shape.
BUT the main issue is the fact they do not flex or articulate very well in the summit. The erevo is designed to have a stiffer less flexible suspension ( helps with high speed stability and cornering). The summit wants as much articulation and flexibility as possible, which would lead to the these cvd arms constantly slipping out of the drive cup or binding into the drive cup.
proj 002: The Funky Gecko
Man, Use Common Sense!!
they would fit on one side...the other side requires shorter shafts because of the space the lockers take up in the bulkhead
Summit w/mamba monster
Stampede 4x4
Boss 302 BL
so u would buy only 3? wheres that gona get you
Those, are pretty sick. Revo axles don't fit with the diff lockers though. I have the center driveshafts and I'd sure like to try out a set of axles for the Summit.
when i break mine the upgrades will be steel
I have been searching for upgraded shafts, but no one seems to make a decent set. MIP makes some for the summit but they have had mixed reviews.
yeah ive read about MIP and everyone has a different opinion
I had those and tryed to make them fit the locker side but no one makes the right length shaft to make it work. IMO they are great for Revos but they will not fit. just my 2 cents
IfYouCan'tRunWithTheBigDogs,StayOnThePorch
Yup... that has been covered.
It would be nice though.
I have to agree with K.
I have a full machine shop at my disposal... I can do what ever I like and make what ever I need. I had plans to make a set of axles for the Summit. Then I got to thinking... the stock axles are $7ish. That makes for a pretty cheap fuse!
Now that I have my slipper adjusted correctly... I have yet to break another axle or strip another differential.
Just a little food for thought.
i have access to alot of machinery but as you said Jimmie for $7 it is easier to just buy stock replacements
