Results 1 to 9 of 9
    Jun 2011
    Haverstraw, New York
    16
    Should I Dispose Of This LiPo?
    Hi, I was wondering if I should just purchase a new battery due to this expansion of a hardcase LiPo. Thanks, and also what percentage of charge should I store LiPo batteries at, I believe my problem here was storing at full capacity.
    u.k.
    1,766
    With softcase lipos you can easily see swelling, when a hardcase expands it's pretty much a goner, Storing at full charge is bad, storing at 50% is better, about 3.85V.
    Alma, MI
    11,964
    If it is swollen, it is no longer safe to use.
    Cells should be at 3.85 volts for storage.... cells, not the entire pack.
    Storing at full capacity will certainly shorten their life span considerably.
    Buffalo NY
    1,330
    If it's swollen, you have to get rid of it. Charging a damaged or puffed LiPo = substantial chance of fire.
    As far as storing it at full capacity...you're probably right that it caused the damage. It's not healthy for LiPos at all. Charge it, use it.
    There is no storage "percentage" per se; you want the packs to be at 3.8v per cell. Get a decent multimeter from Radio Shack to check your packs before and after use (and right after charging).
    Alma, MI
    11,964
    Or a $5 cell checker from eBay.
    To dispose of your LiPo, hook a small load to it like a 12v light bulb and let it fully discharge outside in a metal container. Then you should be able to throw it away.
    Jun 2011
    16
    Thank you for all of your replies, I've heard of a method of placing the battery in a salt water solution, would it be safer to do this?
    u.k.
    1,766
    some lipo information from one of the manufacturers will help also. That way you will have more understanding on what to do. Saves buying new packs and keeping you and others safe from injury. Knowledge is power and an angry lipo can be a powerful beast.
    Jun 2011
    16
    I'm bringing it to the hazardous waste facility to get rid of it. Thanks again for your replies.
    Zeeland Michigan
    1,149
    Lipos are safe to depose in the trash they are Environmentally friendly just make sure they are fully discharged .
    1 Rusty VXL
