    12
    Rear wheel spin: what is normal and what is not?
    Hey guys,
    I have searched and read a bit on this topic but usually any relevant comments are in a thread about a different problem. I am trying to just get a general idea of what is normal for a Stamp 4x4.
    My specific question is this:
    How freely should the rear wheels spin when the Stamp is not powered on?
    I feel like with the MIP's CVD that my rear wheels are binding up. I adjust the wheel nuts....and it seems like its either the wheel is loose and a bit wobbly or it's so tight that the wheels are not spinning as freely as they should. I have used lock tite on my wheel hubs....I have washers and I have made sure the hubs are not rubbing on the bearings or anything else.
    Thanks in advance.
    Also in searching I realize there is no forum or thread that has how freely all of your wheels should spin in relation to each other. There are quite a few that talk about it briefly....but not collected in one place. Just an observation.
    United Kingdom
    626
    If I put it on my desk and give it a good,shove and lift all wheels spin for about 1-2s I think. You have to remember they are stuck to a drive train and motor that all cause a lot of friction. :-)
    Nov 2011
    Portland OR
    381
    Should tighten the wheel nuts as tight as you can with included tool and a little more. Are your wheel hexes smashed and rubbing on the bearing carriers? Running wheel nuts loose will just strip the hex in the wheel. Take a tapered punch or something to make sure ur bearings spin ok.
    Wales in the UK
    5,806
    Your mips could do with some dry lube and that will cure it dude....peace
    Salisbury, NC
    633
    Quote Originally Posted by o0wiz0o View Post
    That's how I check it too. It should roll for a bit if nothing's binding.
    12
    Okay....so a little spin but not too much. Got it. How does the rear compare to the front? The same? Should the front spin a bit more? Thanks again!
    United Kingdom
    626
    It will be the same more or less...well. Mine is.... :-)
    Wales in the UK
    5,806
    The front should spin less because the 30wt oil and grease in the rear....peace
