Results 1 to 9 of 9
    6
    Will a tm523 carb fit a 3.3?
    Hello
    could anyone please help me here please...
    I have a jato 3.3. I have been seeing that alot of people upgrade there carb to the tm523.
    I just bought the rb 8mm carb from amainhobbies.com and been told that it will fit my 3.3 with no modifications?????
    Please any info would be a big help
    thank you
    Jun 2010
    Miami, Fl
    6,731
    Have no idea, but found this thread..
    http://traxxas.com/forums/showthread...on-the-trx-3.3
    6
    Thanks i will check it out.
    NJ
    555
    Yes they fit and work great. The only thing you need to do is cut the plastic isolator off and grind a little flat spot in the front of the carb for clearance. You can use a file to do this.
    Quote Originally Posted by jato.rocks View Post
    Hello
    thank you
    6
    Well I installed the carb two days ago. I will tell you it unleashed a beast. Now very easy to tune. Faster than ever.
    Everyone should upgrade to this carb. TRAXXAS should have updated the carb when they released the 3.3.
    The inner diameter of a TRAXXAS stock carb is 6.5 but with the bigger piston and sleeve it should be 8
    This testing was done by engineer friend of mine and this is the reason I upgraded to the 8mm
    I clocked it yesterday at 72mph with very little mods.
    Thank you for your replys
    4,351
    Try reading this thread, it's on the same subject. LINK Hope this helps!
    NJ
    555
    Thats awesome im just a little curious thow. What tires and what was your gear ratio you were running to hit 72mph?
    57
    how much did this carb cost?
    57
    could you post the part number please
