Results 1 to 10 of 10
    Feb 2013
    Albuquerque, NM
    59
    ProLine wheel trouble
    I just got the Pro-line trenchers mounted on the black wheels. The hubs fit, but when I tighten the nut down the rim still wobbles on the rear hubs. Am I missing something?
    Buffalo NY
    1,330
    Stupid question: are the rims completely flush with the hubs when you tighten them down? If not, they wobble.
    198
    did you get spacers with the wheels? if so use them i got some proline rims came with like 6 packs of stuff for different trucks to get them flush and no wobble and if not that check the ball joints make sure there not falling out
    good luck
    Feb 2013
    Albuquerque, NM
    59
    No spacers were in the bag with the wheels, and yes they sit flat against the hub. It almost looks like the hub flange extends past the wheel.
    Alma, MI
    11,959
    Are you sure it is not the play between the hub and the axle?
    198
    it should be all good i looked at mine it wobbles a small amount looks to be the pin inside the center of the 17mm axles take the wheel off and move the 17mm back and fourth a little u should see the center pin in it move a little. not the set screw. also when i got the same tires and a different rim they moved alot i had the same problem ran them once then sold them for the same price i got them for to some guy. so.... some rims are just a little different. or post a vid of your problem and maybe the traxxas comunity and single out your problem. good luck.
    Dec 2009
    38
    Quote Originally Posted by tmack20 View Post
    ..................the rim still wobbles on the rear hubs.
    What is the difference between the front and the rear hubs?
    If you mount THIS wheel in front? Does it wobble??
    Dec 2009
    38
    Double post, sorry!!
    Nov 2011
    KC
    310
    Theres no difference in the hubs front to rear. Take a close up shot and post it.
    PM me for help converting your Summit to brushless
    Feb 2013
    Albuquerque, NM
    59
    Will work on the picture tomorrow. Thanks for the help.
