Rustler VXL body which does not fit well because of the rear pin
Rustler VXL slipper clutch, the SRT cover does not fit because of the size of the VXL
here is the view of the back where the SRT pin does not fit after drilling the hole.
So I solved the problem of the rear pin by using a wire and a thin piece of plastic as a softner
I had a JConcepts SCT body that had a similar problem.
