Results 1 to 11 of 11
    540
    Charging and Hot Hot Hot
    Just took my Power Cell 8.4 Volt 3000MAH 7 Cell battery that came with my truck off the charger, and I am pretty sure I just burned my hand. I looked and the plastic wrapping on the battery looks like it started melting in some spots. NOT SAFE!!! I also noticed that right before the wired go in under the black cap thing on the battery, the plastic is ripped and the copper wire is exposed. I don't know if I should try and fix the wire, then wrap the battery back in a plastic wrap that I have seen people use for covering batteries. SO, is there a way I can fix it or is the battery as good as dead?
    Dirt Slingerz Racing
    Slash VXL - Summit
    Buffalo NY
    1,330
    That pack is toast, my friend. Bad NiMh cells can explode with great force when charging, so you don't want to mess with it.
    What charger were you using, and what amperage were you charging at? There may have been a bad cell in that sucker, which would increase the resistance in the pack and cause overheating.
    540
    I charged it on my little ProphetPlus Charger at 4 amps I think it was. That was the first time I noticed the damaged wire though.
    Slash VXL - Summit
    Buffalo NY
    1,330
    4 amps is actually a little high for that pack (even though on my Traxxas NiMh it says you can go up to 4A). Charging at 1C (3A) might have extended its life a bit more, but when a cell decides to give up the ghost there's not much you can do. That's probably what happened here...
    On the other hand, suppose the pack shorted out because of the wire. In that case, it's still toast because of the extreme heat it had to endure. I'd still throw it away, sir... Sorry for the loss.
    Jan 2006
    Sydney, Australia
    189
    I got my Rustler yesterday and charged the included NiMH @ 3A and it was warm for the whole charge but got pretty hot in the last 10 mins. It also runs really hot in the VXL and at the end of my run today it measured 170f in pretty cool conditions outside, around 20 celcius. I don't think ill be using it much longer and will break the LiPo out.
    The NiMH also seems to make the ESC run hotter and thought that because the ESC is basically sitting on top of a really hot battery that this could be where some of the extra heat to the ESC is coming from.
    Buffalo NY
    1,330
    Quote Originally Posted by jackpot View Post
    If I'm not mistaken, that's a 3000 mah pack, correct?
    Jan 2006
    Sydney, Australia
    189
    Quote Originally Posted by zippogeek View Post
    Correct, the one that came with the Rustler VXL.
    Buffalo NY
    1,330
    Man, that's pretty hot. A brand-new pack shouldn't get that toasty. You might have a bad cell like the original poster.
    New York State: Snowbelt
    747
    My packs in my summit get hand burning go everytime I charge them, but they have been through snow, water, mud, sand, and all that happy stuff.
    Jan 2006
    Sydney, Australia
    189
    So i switched to 2S LiPo and charged it at 5A. The battery was barely warm when it came off charge and didn't hit over 80f on the same surface i was taking the 8.4v NiMH on. The ESC and Motor also ran much cooler. Impressed!!
    Buffalo NY
    1,330
    Glad to hear it. Everything is better with LiPo.
