Results 1 to 18 of 18
Thread: Motor Sizes?
    Chehalis, Wa
    436
    Motor Sizes?
    Ok. I got a brushless motor on a trade the other day and its a 2370kv. It's the same diameter at the velineon motor but its about a inch longer. What will happen If I put that motor in my slash. I know there will be more torque but what else. Should I not put it in there and go with a higher KV motor?
    _______^_
    /______l__\____
    l_l O l_____l O l
    El Sobrante, Ca
    7,543
    Do you know what brand of motor it is? Is it a two or four pole motor? The more information you give, the better answer you will receive.
    Chehalis, Wa
    436
    No name off brand. It's a GV motor.
    _______^_
    /______l__\____
    l_l O l_____l O l
    Long Beach, California
    6,405
    you think you can post a picture?
    | Rally GT8 Powered By CC |
    El Sobrante, Ca
    7,543
    Quote Originally Posted by Keila72 View Post
    Do you know if it is a four.pole motor? Does the truck roll smooth or choppy?
    Chehalis, Wa
    436
    It wasn't in a rig. It was loose. And it spins freely and smooth.
    _______^_
    /______l__\____
    l_l O l_____l O l
    6,405
    El Sobrante, Ca
    7,543
    It has a 5mm shaft. You are going to need a different pinion to fit the larger shaft. If and when you do run it, please report to us how you like it.
    Chehalis, Wa
    436
    I have a few summits and a ton of pinion gears. What are the advantages and disadvantages to the smaller kv motor.
    _______^_
    /______l__\____
    l_l O l_____l O l
    Southern louisiana
    61
    A plus for lower kv motor is, u can run higher cell batteries and if geared correctly it will fly and temps won't be as high as a higher kv motor. Fun for bashing!
    Slash rx8 tenshock 4000/Mugen mbx6 Eco rx8 t8 2650
    Southern louisiana
    61
    Oh and disadvantage is it may not perform that great on 2s. 3s to 4s would be good tho
    Southern louisiana
    61
    As always keep an eye on temps and find the best combo of gearing/ battery size!
    Nashville, TN
    1,776
    It should be good on 3S, but watch your ESC temps. The VXL-3S is made more to run 540 size motors.
    That is a 2-pole motor, right? The VXL-3S doesn't like 4-pole motors as much.
    If you end up changing ESC's, the castle mamba max pro is a good option. There's a losi-branded identical version that's cheaper too (LOSB9504) on eBay.
    Chehalis, Wa
    436
    Quote Originally Posted by Patrick180 View Post
    I havr a esc and motor fan for the 2370 motor.
    I'm not sure what pole. How do I tell?
    _______^_
    /______l__\____
    l_l O l_____l O l
    Vacaville, CA
    25
    I have that same motor. It is a 2 pole. Works great on 4s not so good on 2s. It came off my XTM Rail. Have it connected to a 120a ESC
    Revo OS 21TM, ERBE, SLASH 4X4, RAIL
    Chehalis, Wa
    436
    Quote Originally Posted by gu671am View Post
    I have the esc that for a with it but the guy I git it from cut all the wires off and took ut apart and lost the covers and there is more silicone on it then comes in a tube.
    Did you try it with the stock slash esc? Are you running it in your slash. If so can I see some pics. I would like to see how you mounted your esc.
    _______^_
    /______l__\____
    l_l O l_____l O l
    Vacaville, CA
    25
    I tried it in the slash but decided to put it back in the rail. I never tried it with the stock ESC. The bullet connectors are different sizes. As far as mounting it bolts right in. Had to relocate the reciver to the front of the truck. Would also recommend upgraded Drive shafts if your gonna if your gonna run anything bigger than 2s. The motor is ok. Cogs alot. But ripps when you get it to speed. Also would recommend a aluminum heat sink and fan.
    Chehalis, Wa
    436
    Here is how I mounted mine.
    Photos including banned products are not permitted.
    -ksb51rl
    _______^_
    /______l__\____
    l_l O l_____l O l
