Thread: 7.4v 7600mah
    1,161
    7.4v 7600mah
    How do the above lipos hold up and what kinds of run times? I'm looking at getting a set for my summit. The shop I order from has them for 79. Thought that was pretty good price since I just spent 50 on nimh
    Zeeland Michigan
    1,192
    I would think about 40+ mins, with the 7600mah and it has to do alot of how you run it , flat surface , grass , dirt .
    1 Rusty VXL
    1,161
    my yard is a mix of everything,, hills, both short and long grass, you name it i got it.. im getting about 20-30 min out of my nimh.. Im more concerned about if they are going to fail pretty quick . I live on the Canada side of things and everything else seems to be the same price for less mah
    Alma, MI
    12,279
    Voltage and mAh does not tell us much... many different manufacturers can have the exact same specs and not all manufacturers are created equal as far as quality goes.
    My 7,600's last at least an hour with mixed driving in my Summit... that is switching between high and low gear. If I am just crawling around, I have gotten a couple hours out of them.
