Results 1 to 18 of 18
    469
    New to the e revo club
    Hey guys, i know nothing about the e revo, i just bought one today from this guy for 400 bucks he took the motor out and had it in his losi but gave it all to me. I soldered new traxxas plugs on it to. Im using 3s batteries to is that fine?
    Okay i know nothing about this either but it needs a new spur gear and a pinion. What is a good gear set up to use?
    469
    Some pics what all i got
    469
    All rpm.parts and big joe tires and on road tires, all steel driveshafts and a extra set
    kansas
    7,820
    18/54 is a good start, & up depends on you temps.
    reading material...
    AOD's Links Revo
    Erevo 101:
    EREVO FAQ
    Lipo, LVC, Brushless & Battery charger/charging guides & purchasing links:
    TUTORIALS
    Refer to this to setup the Mamba Monster ( MMM ) esc for maximum performance:
    CASTLE LINK GUIDE
    Refer to this to find parts, upgrades, batts & chargers etc:
    USEFUL LINKS
    And direct from Castle Creations ( the esc manufacturers ):
    MMM FAQ
    Driver's ED Manual
    LED warning light meanings
    469
    Thanks for posting all the links. So is 18/54 stock gearing?? Does the motor get that hot with 2 3 cells
    so cal
    9,244
    You will probably end up around 21/54 but 18 is a good starting point
    65t spur is stock
    On 6s it will heat up faster then 4s and much harder on the diffs and axles. Only way to tell is drive the way you do and check your temps until you know how hot it runs.
    I would start with 4s and get used to the power
    kansas
    7,820
    Quote Originally Posted by brandon32689 View Post
    yes it is the supplied gearing.......yes "can" get hot both the ESC & the motor....the Joes are a heavy tire, would stick around the 18/54 mark still a lost of speed.....
    A temp gun is kind of a must have.....
    Hot motor + cool esc = under geared.
    Cool motor + hot esc = over geared
    Everything warm just right..
    Motor ~ 180/190*F (82/88*C) maximum, ideally 140/160*F (60/71*C), temps can be 10*F higher inside the motor
    ESC ~ pretty much same temps / Fan comes on @ 150*F (65*C)
    Lipo's ~ 140*F (60*C) max, ideally 100/120*F (38/49*C).........
    469
    Okay guys i font really have a option on batteries have to be 6s cause all i own is 4 3s batteries. Well sweet i have a ton of 54 spur gears for my slash and i have the rr one to i don't use in the slash.
    Should i be fine with 18/54 then for all around bashing. I got a temp gun. I have a fully upgraded slash
    so cal
    9,244
    That depends on your driving style and terrain but you should be fine
    Do you have a castle link? You can mellow out the hit and make it more livable
    Pu a matching 2s then you can run 5 cell!
    469
    Hey does the batteries have to match to?
    kansas
    7,820
    to much..?? what
    Voltage..? No the MMM is a Max 25.2v
    So it can run 2/3s (6s) no prob, just watch temps
    I hope your 3s are in the 5000mAh & 30C~40C range....150amp~200amps
    more info on that in the link.....
    same ESC just water resistant....
    http://traxxas.com/forums/showthread...=1#post5400474
    469
    to much..?? what
    My lipos are onyx 5000mah 3s 25c and i have one venom 3s 5000mah 35c will these work? Sorry man I'm still a noob to these. I got a slash 4x4 that I've been playing with for last 2 months.
    kansas
    7,820
    that works need a min of 120 amps
    5000 times 25 = 125,000 divide 1000 = 125 amps......
    cell count remains the same..
    mAh x C = ???,??? '/, 1000 = amps
    8000 x 50 = 400,000 divide 1000 = 400 amps
    the more amps the better.........
    check out a few of the build threads, you can pull alot of info....
    469
    Thanks for the help man what if i have another battery to that is a venom 5000mah 35 c can i run it with a onyx batterie or do specs have to match?
    My buddy said hed trade me two 2s 5000mah 20c-50c for 2 of my onyx should i do that
    Traxxas has a strict language policy. A word filter operates to change inappropriate words and banned websites or brands to *s. When you see these in your post, you MUST edit them out.
    -ksb51rl
    kansas
    7,820
    best to have all spec the same
    mAh
    C
    Brand
    number of cycles
    if you see starts in your post edit them out.........that brand of batt is not allowed here.......
    so cal
    9,244
    that is only accurate when the factory rating is accurate which is rarely the case most are overrated
    My buddy said hed trade me 2 2s 5000mah 20c-50c for 2 of my onyx should i do that
    i wouldn't 20c battery is much weaker than yours
    they have to match by mah and C rating i run spc 5400 50c .i have 4 2s and 2 3s and then i can run 5s with one 2s and one 3s
    kansas
    7,820
    That is true to a point. Some not all Battery brands are over rated (kind of). Not pointing any fingers as to who is or is not "over rated".
    What some are doing is basing their C rating off Max Burst, not Continuous discharge... It is misleading but it is still true, to a point........(KIND OF). Buy good named batts & you should never have a prob.........
    Oct 2012
    Perth, Western Australia
    53
    Still putting together my E-revo roller but will be starting with 18/62 with 2/2S and going from there.
    MM2/2200kV combo. I checked rear diff cup and almost no oil so filled with 100k. rebuilt shocks with no3 VDK and 70W. Talons on 1/2 offset Desperados with HPP hubs.
    50togo, 20 plus posts/day. You're a busy boy.
    Jayson
    Summit BL HW SC8 2000kV
    E-Revo MM2 2200kV
