Results 1 to 18 of 18
    Atlanta, GA
    121
    Any rocker recommendations?
    Hi everyone, just wondering if anyone has these rockers http://www.hobbyetc.com/item.cgi?part_id=62557\
    I just dont want to pull the trigger if anyone has had issues with these rockers? I mostly do a lil light ofroading and high speed bashing in parking lots. I see the above mentioned rockers have two mounting holes, for progressive spring tension. Any thoughts?
    Thanks everyone in advance.
    so cal
    9,244
    Those look good!
    Atlanta, GA
    121
    50 what do u run?
    Atlanta, GA
    121
    I was also looking at ordering this engine mount to help assist with some heat transfer http://www.hot-racing.com/index.cgi?...=VXS1801;c=455
    I'm running 3 cell and 23 tooth pinion, want to help the motor as much as I can with keeping the temps down and some heat transfer awat from the motor.
    So Cal
    521
    Those look good!
    eeek !
    to each his own
    I just got some vanilla flavored (silver clear anodized) ST rockers and I like em
    but, they are visually.... uneventful - Ha!
    There are lots of ways to do that. Most are wrong.
    so cal
    9,244
    I run gh rockers on my merv. Work pretty good!
    I have that mount on my other merv. No complaints!
    Atlanta, GA
    121
    They also make them in carbon fiber. Debating aluminum or carbon fiber at this point? Any thoughts hehe?
    so cal
    9,244
    I would go aluminum
    This is on my erbe
    Atlanta, GA
    121
    Would carbon fiber be too brittle on jumps and abuse? I love the carbon fiber look, just worried about longevity.
    Atlanta, GA
    121
    Ok so Aluminum it is!! Thanks 50!. Hows the aluminum with flexing and on jumps 50?
    So Cal
    521
    Hey 50 who makes the chassis brace ? you? (right above the shock condoms )
    I like that
    Never mind, that's a "monster" revo i now see
    recalculating...
    581
    Quote Originally Posted by linux38 View Post
    I made front rockers out of pure carbon, and thrashed the heck out of my MERV at the skatepark until the chassis broke, and the carbon rockers were intact. I went back to stock because they needed to be constructed with a little more precision, there were no bearings or bushings, the surprising part was the screws threaded into the carbon fiber. I like the HR look but I am turned off by the fact that there's only one plate holding the pushrod, it isn't captured.
    I like turtles.
    Atlanta, GA
    121
    What do the chassis braces do?
    So Cal
    521
    Quote Originally Posted by Meebert View Post
    Nothing wrong with trying - you get an A for effort
    Atlanta, GA
    121
    So the product descriptions state they are rear rockers, and i dont see front rockers? Can I order 4 rear rockers, and use them all around on 4 corners?
    so cal
    9,244
    recalculating...
    581
    no the rears are different, they won't work up front. They do make fronts you just have to find them
    Quote Originally Posted by photon_trap View Post
    It was definitely worth the build, especially because they were durable. The precision wasn't perfect because I made them with a minimum number of dremel accessories. Now that I have a drill-press type dremel attachement I could probably make some good quality ones, they would look so good with rocker arm bearings
    I like turtles.
