Can you run a 1200mah and a 1600mah in series or in parallel?
"growing up just sounds boring...I'll pass"
Most would suggest neither.
It is better for both batteries to be the same when ran in either configuration.
But, it is possible in theory to run two dissimilar mAh counts in parallel together, with all other aspects the same.
Thanks jimmy that's what I thought but wanted to double check...
