Results 1 to 16 of 16
    417
    30c or 70c lipos?
    I have my emaxx running 4s. 30c lipo would I see a difference in speed and perfgrmance going 4s 70c?
    EMAXX 1480kv 6s
    RUSTLER 2150KV 4S
    California
    4,840
    that will depend if the lipo is rated accurately as far as C rating goes.
    You know you cant just run 1 4s lipo without capping off the other end of the esc lead.
    DEU 8:18 ESV
    Sep 2011
    1,350
    As I understand it, the "c" rating is a measurement for how well battery can handle or allow an amperage draw. I don't think you'll see a change in performance. But what you would gain by going with 70c LiPo's is that they won't work as hard to supply the ESC/Motor on high amperage demands. On hard braking or hard throttle punches the amperage draw on the battery is high.
    At least this how I've made sense of it all.
    California
    4,840
    M n M is right on the info given as i have learned. High C ratings are good for brushless editions
    DEU 8:18 ESV
    so cal
    9,244
    I think a 30c battery is on the low side of being strong enough especially if its overrated.
    I would probably accelerate better but not very noticeable
    417
    Ok I notice. When I used a bigger pinion there was some cogging I guess. That was not having enough amps form the batteries
    EMAXX 1480kv 6s
    RUSTLER 2150KV 4S
    Alma, MI
    12,280
    The C rating does not mean a whole lot without any other info...
    amperage capability calculations require mAh as well as C rating.
    so cal
    9,244
    but with no standard for C rating even that doesn't mean much
    417
    My lipos. I have are 2 2s 5000mah. 30c. I was looking at getting. 2. 2s 6000mah 70c. Gforce lipos.
    EMAXX 1480kv 6s
    RUSTLER 2150KV 4S
    so cal
    9,244
    Alma, MI
    12,280
    Very true.
    I would also like to add that experienced hobbyists know from experience or research which brands are more realistic with their C ratings.
    so cal
    9,244
    I have tested multiple brands not only voltage drop but mph on my merv up to and over 65mph
    Feb 2013
    32
    I am running 2 2s 6000mAh 35c right now on a mm brushless set up. If i get two 2s 5900mAh 60c the only thing that woud really change is the run time with the more C? I am still new to LiPos. thanks
    so cal
    9,244
    No tiny bit less run time from the smaller mah but more punch from the higher C rating
    But of course that would depend on if they are the same brand as there us no standard for C ratings between battery companys. So they are free to exaggerate
    Feb 2013
    32
    The mamba monster set up can handle 4s right?
    Do any of you guys know where i could purchase gforce lipos from that can ship to Canada? thanks
    15,548
    Quote Originally Posted by Complexd View Post
    The system is rated for up to 6S.
    Nope.
    Alt-248 on the number pad =
