Results 1 to 23 of 23
    sacramento, ca
    742
    Tire question. Canyons or mashers?
    I have both canyons and mashers and was curious what everybody thinks is the better all around tire? I do a little bit of everything with my maxx. On road, grass, off road, a little crawling, just like to smash around with this thing. Also has anybody had any success taking the crome off the stock wheels? I'd like to get them back to plastic and then dye them black.
    addicted much....
    9,244
    Oven cleaner will probably work
    I have the mashers in 3.2 on my t maxxes and the mini canyons on my merv both are my old favorites!
    1,350
    I've had the Mashers. They are good tires, a little soft but good.
    Oven cleaner should do the trick in de-chroming those wheels.
    sacramento, ca
    742
    I've been using the canyons ever since I went brushless, they seem really soft. They have decent on road traction, but It seems like the softness kinda limits speed. Ill give the mashers a try. I just replaced my bulkheads, shocktowers, shocks, driveshafts, toelinks, a-arms and knuckles with upgraded parts. Turned out really nice. Hopefully switching the tires wil get me dialed in.
    addicted much....
    9,244
    I think mashers would be good. I would take the canyons off the rims and put some road tires and get some offset desperados and badlands for the dirt!
    1,350
    Gorilla tape the inside of the Mashers before you mount them so you reduce the ballooning effect.
    sacramento, ca
    742
    Quote Originally Posted by M n M View Post
    Definitely! I only run 4s with stock gearing at the moment, so ballooning isn't so bad. But I have my eye on some spc 3s batts.
    addicted much....
    9,244
    I would start off running 5s before the 6s!
    Jan 2007
    1,549
    Mashers for the win! If you do use the oven cleaner, heed their warnings, and wear rubber gloves and keep your eyes on things. Nasty stuff. I've used it to take the annodized color off of aluminum parts. If you let it soak too long, it starts to pit the aluminum. Guess what it will do to your skin.
    sacramento, ca
    742
    How does that work? I think I've read something about having to run 3s on one side and 2s on the other.
    And as far as the chemicals go, no big deal I paint cars so I have a respirator and gloves. Ill take the rims to work to strip them.
    addicted much....
    1,350
    Quote Originally Posted by the finisher View Post
    If memory serves, you'll want to plug the 2s battery into the BEC side. The BEC side draws more power then the non BEC side. So, the LVD will kick in when the 2s battery is low and prevent the other battery from being draw down to a damaging level. If you wire it the other way, by the time the LVD kicks in on the 3s the 2s battery will have been overly discharged.
    The other thing you'll need to make of is that the 2s and 3s are the same MAH rating.
    Victoria B.C Canada
    5,150
    If you plug a 3s into the bec side.
    Smoke will follow right after the button gets pushed.the new version of the evx2 with lvd won't allow you to run 5s goes into over voltage protection mode
    Sent using lipo power
    Mountains cant stop me
    they have tried
    sacramento, ca
    742
    I have xerun 150a esc in it. So no evx2. I'm pretty sure its capable of 6s. Do I still need to worry about what side each battery is plugged into?
    addicted much....
    1,350
    Hmm I'm not sure on that. I think that some of the exrun ESC's can have the LVD set to different levels. So I'm guessing that you'd want the LVD to kick in at a safe level for the 2s. Again, I'm guessing here based off my experience. Hopefully some one with more knowledge will chime in.
    May 2010
    263
    Big joes on axial 40s bead locks
    Slash rocks!!!
    9,244
    spc recommends low voltage set at 3.5v to be safe
    sacramento, ca
    742
    I'm pretty sure I keep lvc at 3.5 or 3.4 on all my adjustable esc's. But what you guys are sayin is, I can use a 3s and a 2s battery, for 5s as long as they are the same mah? Is that correct?
    Edit: just re-reading m n m's post. Are you talking about setting lvc individually for each battery?
    addicted much....
    9,244
    That's right 5s is a good kick over 4s without the hard punch of 6s
    And yes should be the same mah and age if you can
    Victoria B.C Canada
    5,150
    My mistake ...no that is not a issue
    You are running a series connecter
    To make 5s? and the esc has a single input it sees it as 5s so doesn't matter what side it's on.
    they have tried
    sacramento, ca
    742
    Ok cool, I'll probably make a order with spc in the next week or two. I ll see if I can get a 5s combo figured out. I'm perfectly happy with 4s but I want a little more speed. That's another reason I was curious about the mashers.
    addicted much....
    9,244
    When I bought my spc batteries I bought their 5400 50c 2s and 3s for that purpose!
    sacramento, ca
    742
    Speaking of spc, how about they're shipping. I ordered some batts for my merv on wednesday morning, now its friday morning, and usps says they're out for delivery!! Yet another reason that company rocks!
    addicted much....
    9,244
    Yep. They stay on top of that!
