    191
    New tires for E-Revo BL
    What tires is recommended for this car?
    The stock one did shred...
    I have Pro-Line Trencher X 3.8" on my summit, so maybe somthing like that?
    Do i have to gear down / up if i use Trencher tires on a E-Revo.
    kansas
    7,838
    what are you geared now & 4s, 5s or 6s...??
    which Trenchers org or Trenchers X..??
    which ever tires you get tape them..
    taping tires
    post #30
    http://traxxas.com/forums/showthread...=1#post4908845
    post #130
    http://traxxas.com/forums/showthread...=1#post5177829
    191
    Its my brothers car.
    The car is stock. Im not sure what gear thingy is orignal. I have just heard taht if you change the tire size, you must gear down/up something.
    He is using 2S batteries, so 4S total.
    Sent from my ASUS Transformer Pad TF700T using Tapatalk 2
    so cal
    9,244
    If he has stock tires and gearing then he might be ok ! Trenchers x are much taller then stock but I went from stock gearing to 22/54 with stock tires
    Just keep an eye on the temps til you know how hot it runs the way you normally drive it
    kansas
    7,838
    2/2s you should be ok with the stock gearing 18/54, with about any tire combo.
    Even with the Trencher X, just watch the temp the first few runs to get an idea of temps..
    A temp gun is kind of a must have.....
    Hot motor + cool esc = under geared.
    Cool motor + hot esc = over geared
    Everything warm just right..
    Motor ~ 180/190*F (82/88*C) maximum, ideally 140/160*F (60/71*C), temps can be 10*F higher inside the motor
    ESC ~ pretty much same temps / Fan comes on @ 150*F (65*C)
    Lipo's ~ 140*F (60*C) max, ideally 100/120*F (38/49*C).........
    191
    Outside temp might have a impact too. We are driving in snow now. It's about 0C outside now.
    So the Trencher X would be OK?
    I have them on mine, and the traction on snow/ice isnt the best, but it works.
    so cal
    9,244
    Cold weather will definitely help
    Try it and check temps after a few to see how warm it is
    kansas
    7,838
    Quote Originally Posted by rvenes View Post
    If you get that much snow might build some snow chains. think I used #12 not #16 jack chain...
    http://traxxas.com/forums/showthread...=1#post4990818
    191
    I have snowchains for my summit. Not sure if he wants to do that.
    Think he will go for the Trencher X tires.
    Trencher X without snowchains.
    Summit on snow (and ice under the snow) with Trencher X and snowchains.
