Results 1 to 17 of 17
    285
    Would this crack make it not waterproof ?
    Just installed a new fan for my motor but I'm wondering about the rx box. Would this gap from my fan wire un waterproof it?
    Sent from my iPhone 4s using Tapatalk
    Maryland
    325
    That opening will allow moisture in because the o-ring will not seat properly. Run those wires in through the front where the others are and you will be good to go
    No Limit RC of Maryland
    285
    only problem is the wire isn't long enough.. ill see if i can strech em a bit lol
    South of St Louis
    4,994
    You can probably adapt a servo extension to fit if you need more length.
    Maryland
    325
    What does the wire attach to? A telemetry sensor?
    285
    No luck getting it around, wires just to short.. It is a cooling fan
    2,188
    Use a servo extension wire.
    Sting like a butterfly and punch like a flea, jack
    285
    Ok.... What's that? It's comes with an extra wire that you can plug the end of the fan wire into it and then then other end is open 2 wires .. Would that work?
    Maryland
    325
    Quote Originally Posted by idkhow101 View Post
    plug it into the red connector on the left side of the esc. That is made to plug the esc cooling fan into so it should work fine. If not use an extension wire like others have said
    Anthem Arizona
    362
    Here is one
    Rc...my wallet hates it...but my brain loves it
    Toronto
    2,138
    Or just re-mount the fan so the wire is coming out of it facing the ESC box. Of course having it open like in the first pic allows water to get in, it's open! You must run it through the same way all the wires come out, and if you need an extension it's certainly worth the $2 in parts from an LHS to make it work!
    I wouldn't suggest plugging it in to the ESC because that is only powered when the ESC needs it I believe, not all times.
    285
    ^ the wires have the same end...
    Maryland
    325
    My fan runs all the time when plugged into the esc plug...
    Toronto
    2,138
    Interesting, I ran the VXL-3S and Velineon 3500 on my mini e-revo and the fan never came on, the VXL was always cold to the touch. Maybe there are software changes between ours, who knows... hope it works out for the OP!
    285
    Well guys, i got it. What i ended up doing is the taking the extra wire that comes with it. (the wire has the plug in where you can plug the already connector of the esc/ the main connector for the fan into it. On the other end is two wires. All i did is pluged the esc into that end and took the other two open wires, put red in red black in black and electrical taped the heck out of it. i then shoved it under by the battery wires. For now im not sure that the esc needs it, its never past a little warm to the touch but the motor gets a bit hot... This motor and esc will only have to do my probably into the summer so i can get my new motor and esc which will probabably end up being the tenshock sc401+ WP SC8! Can't wait!
    As always guys, thanks for everyone who helped in this thread once again!
    156
    Lol go for it... I dunno when talkin about electronics, that the phrase, electrical taped the heck out of it... is a good thing?
    South of St Louis
    4,994
    Quote Originally Posted by SlashDigger View Post
    same here, with my stock TRX fan.
