Results 1 to 15 of 15
Thread: Cooloing fan
    Wherever
    27
    Cooloing fan
    Cooling fan? should i get 1
    Oct 2012
    Germany (near Bonn)
    236
    No... you should get 2. One for motor and one for esc.
    Jacksonville Fl
    122
    +1 on the fans for both esc and motor. Its cheap insurance to have for your electronics.
    Sent from my Samsung NOTE 2.
    Sep 2012
    FarNorCal
    273
    +1 to exactly what Beholder said!!!!
    rc10T3, TT Sparrowhawk XXB, Slash 4x4, 1/16 Rally
    Minnesota
    1,306
    I was thinking about some fans too. I don't need them right now as it's winter but I was wondering is this a good fan? Or should I just get the traxxas fans?
    ERBE
    Savage Flux XL
    Trail finder 2
    Maryland
    334
    The traxxas fan works very well for the esc cause it snaps directly to the cooling fins with no modding. The Castle cooling fan for the motor is plastic and does not disapate the heat very efficiently. The Integy cooling fan may be a better choice for the motor
    No Limit RC of Maryland
    Minnesota
    1,306
    Isn't the integy fan really loud?
    ERBE
    Savage Flux XL
    Trail finder 2
    Aug 2012
    186
    Quote Originally Posted by Fr8cture View Post
    Maybe a lil but not bad, i like hearin it, lets me know its working still
    Minnesota
    1,306
    Which one do you use single or dual fan?
    ERBE
    Savage Flux XL
    Trail finder 2
    Oct 2012
    Easton, MD
    615
    I just shoo gooed on a pc fan to the integy heat sink.
    Tested before fan in 37deg ambient 198deg.
    Tested after fan 36deg ambient 167deg.
    Both after HEAVY bashing and constant full throttle/full brake.
    (Stock motor)
    Sent from my DROID2 GLOBAL using Tapatalk 2
    El Sobrante, Ca
    7,885
    I have an Integy fan on both of my trucks! Its cheap insurance and even tho I really don't need them. Better to have them and not need them , than to need them and not have them.
    Aug 2012
    186
    Use single, both on my mini revo and slash 1/10
    Oct 2012
    Germany (near Bonn)
    236
    For the ESC there were no alternatives to the Traxxas fan.
    And when I think of a motor heatsink/fan combo there is only one system I can think of: EZRUN 5V Cooling Fan & 36 x 55mm Motor Heat Sink AC225 (11$or less if you search a lot). Ok, you have to dremel the heatsink to your needs because its a little bit larger, but thats part of our hobby. The fan is really huge monster and I run it for about 5 months without problems. I just heard bad thinks about other fans because you have to change them frequently because of the small size (Integy, Hot Racing...).
    Here is atthread link to it. http://traxxas.com/forums/showthread...a-heatsink-fan
    The way to make it fit to a slash 4x4 is a little bit different! If you need help to make it fit perfectly - just let me know it!
    Sep 2012
    FarNorCal
    273
    The integy and hr heatsinks work very well......but the fans that come with them are not the greatest!!! I use single fan set-up, and when the fan died, I replaced them (my son's Slash also) with a Losi fan.....6 months and they are still work'n....
    And WOW briandee......now that's a fan!!!!!
    Canada
    560
    Do not get the castle fan. I got it for my car, and it's really bad placement. It makes your wires stand straight up and almost cuts them. It works fine, but if you put the ziptie to hold down the other side, you CANNOT adjust the motor mount to it's lowest position so you cannot use 50 tooth spur unless you use a 18 tooth pinion.
    http://s1297.beta.photobucket.com/us...tml?sort=3&o=0
    It doesn't stay on by itself without the zipties and could cut the motor wires if you don't put a ziptie on. If you have a castle motor, it's good but not for a stock slash 4x4. Get the Integy fan and heatsink, this one is only a fan. The integy sits nicely and doesn't interfere with the wires. The integy is also a heatsink so it disperses heat better.
