    Wright City, Missouri
    66
    Safe discharge amp rate question
    The correct way to discharge a lipo is to set the amp rate at half the mah rating. Is this correct? thanks. Or is it ok to discharge at a higher rate?
    4,840
    Its OK from what I know to discharge at 1c the same mah as stated on your lipo. Stop when the lipo gets to 3.85v per cell. If your storing it. Lipos shouldn't go below 3.2v at all to be safe and not damage the lipo or your self.
    DEU 8:18 ESV
    Alma, MI
    12,281
    You can discharge the LiPo at up to its constant discharge C rate... which is way more than most chargers (or dischargers) can discharge.
    For instance... a 20C 2200mAh LiPo can be discharged at 44 amps.
    To calculate the constant discharge rate of your pack
    mAh x minimum discharge C rate / 1,000 = available amps
    For example:
    The same 2200mah 20-40C pack.
    2,200 x 20 / 1000 = 44
    This battery pack can consistently provide up to 44 amps.
    66
    Thanks. I have a dynamite passport ultra & it will automatically stop discharging at a safe level.
    66
    For example:
    The pack that you used as an example is the exact size pack i am discharging. It's for my Parkzone mustang. Thanks.
