    Turkey
    13
    Slayer Pro EZ Start Start Up Issue
    I was bashing carefully on a grassy surface 2 days ago it was shutting off as soon as i leave throttle but when engine gets warm this problem gets solved. Anyway after half an hour i end up in a little puddle and air filter got wet. I tried to ez start but it didn't respond. My ez start cables were messed up so i bought new ones installed today. It started but again as soon as i left throttle it stopped. When i pull the throttle it runs and revs normally but dies when i leave it. I checked glow plug several times and it glowed. I tried glow plug igniter and nothing changed. Btw ez start motor works just fine.
    What can be the problem?
    Slayer Pro 4x4 a.k.a. upcoming SnowSlayer
    11
    Have you taken the engine apart to make sure that water didn't get into the motor?
    Turkey
    13
    Yes I opened cylinder head and cleaned the water in engine. With a plenty of WD40.
    Edmonton, AB Canada
    474
    check your idle gap.... check your lsn..
    Turkey
    13
    Both them are set as the factory settings.
    Tucson, AZ
    69
    It is likely that your engine needs to be tuned. If your settings are still at factory setting and the motor is broken in you are probably out of tune.
