Results 1 to 10 of 10
    Baton Rouge, LA
    1,066
    Break/fix Parts ID
    Obviously I'll need a new a-arm, but does this mean I need a new axle carrier as well?
    / 16
    Pittsburgh, PA
    662
    No you shouldn't need a new axle carrier as long as when you reinstall the pillow ball back into the carrier it still stays in place and doesn't fall out. From the pic it looks like you may be right on the edge since I see a bit of damage where it popped through.
    Baton Rouge, LA
    1,066
    Gotcha. Guess I'll pick some up just to be safe. I'm going RPM for the arms; any recommendation for the carriers?
    / 16
    muscoda, wi
    1,245
    i run aluminum black hot racing on my merv. and summit has silver gpm. there both good carriers. i think there are a couple of other types.
    Pittsburgh, PA
    662
    I run the stock carrier with the optional aluminum pivot caps tra7033x. I never have a problem with them and they're cheap to replace a stock carrier over an aluminum one.
    Baton Rouge, LA
    1,066
    Quote Originally Posted by Maxximum Overdive View Post
    Good deal! I'll check it and get on ordering.
    / 16
    Alma, MI
    12,281
    Baton Rouge, LA
    1,066
    Thanks! I forgot I had seen that thread. It's had some action since my last viewing.
    / 16
    Baton Rouge, LA
    1,066
    Is the HR kit all that needed to replace the stock parts?
    "Item #: VXS2101
    Description:
    Hot Racing\'s Aluminum Knuckles ( Axle Carriers) for use on the Traxxas 1/16 Mini Revo, Mini Slash. #VXS2101
    This is the set of black anodized aluminum axle carriers (steering blocks) for the Traxxas 1/16 Revo and 1/16 Slash. The axle carriers or steering knuckle support the stub axles and bolt to the upper and lower suspension arms at each wheel.
    FEATURES: Replaces damaged axle carriers and steering blocks cnc constructed of aluminum.
    YOU WILL RECEIVE: Two aluminum steering blocks, four aluminum o-ring lock pivot ball retainers, one hex wrench.
    This item is intended for these models:
    Traxxas
    1/16 E-Revo VXL 7108
    1/16 Slash 4WD VXL 7008"
    / 16
    Pittsburgh, PA
    662
    Yes that's all you'll need. If you want to do all four corners you'll need to buy two of those.
