Results 1 to 3 of 3
    Kansas
    A few technical Jato questions
    I had a Jato with the 3.3 given to me and its in pretty bad condition the 3.3 motor was blown so I replaced with a new one but I haven't broke it in yet due to other issues I am working on. One of the issues I have is how much fuel line should be between the carb and tank and how far should the fuel pinch be from the carb?
    Pa
    480
    I use between 12 - 15 inches of line. I keep it coiled. The pinch is approx 2 inches from carb. The more line you use, the longer run time
    527
    Personally, I just run my line straight from the tank to the carb.
    The extra length means the engine will still run if you accidentally flip your car.
