Results 1 to 10 of 10
    38
    forward only conversion question
    ive decided to do the forward only conversion on my 3.3 but before i order the parts i have a quick
    question.
    on paper, the robinson racing conversion set looks better, but is there any reason i shouldn't get it and
    get the traxxas kit instead?
    my revo is and will always be a basher.
    Long Beach, California
    6,590
    do you have the link for the RR FOC? RR gears are hardened steel so they are much better and stronger than the stock plastic but they are also heavy.
    38
    i actually dont know how to link things, i figured the weight would only be a problem in racing, but if anyone knows any
    alternatives id love to know.
    the RR set is fairly expensive.
    6,590
    yep they are. i have the whole set (wide ratio).
    north east iowa
    149
    With a stock 3.3. The Traxxas foc gears are strong enough. The RR is overkill for a 3.3. I got the RR steel gears, but I also got a big block motor.
    If it ain't broke, fix it till it is! BB Revo
    79
    Heavier gears=higher rotational mass=slower revo. The traxxas FOC is a wider stronger gear than stock.
    Sent from my DROID4 using Tapatalk 2
    Concrete does not digest well...
    1,994
    The traxxas final drive gears are plenty strong enough.
    Norfolk, va
    1,167
    We still have a few Nitro Revos in our stable, one with the 3.3, 2 with picco .26's (one still has reverse) and an HPI 5.9, all with the stock Traxxas gears and RR Spur and Clutch bell. I recently sold 3 other Revos, 2 with Picco .26's and 1 with a 3.3, same setup, traxxas gears and RR clutch bell and spur. 16/40 gearing.
    We beat the crap out of those trucks and the gears held up fine.
    I do have a complete set of RR gears, but never got around to installing them, it does make the tranny much heavier.
    38
    ok i have another question, same general area so i thought id just tack it onto this thread instead of starting a new one
    will i still be able to drive my truck if i pull the opti drive and the reverse servo out and leave the reverse gears in the transmission
    until i get the foc?
    my reverse servo started playing up on me today.
    9,758
    Yeah. Just have to lock the rod in forward--you don't want that slipping out.
