Thread: No fuel?
    7
    Question No fuel?
    Got my Revo 3.3 out of storage, charged every thing up, fueled it. Tried to start it. Cranks fine, but won't pull fuel from tank to carburetor? Dad says he had same problem, had to replace piston rod and that worked. So that's what I did. Didn't work?
    Ideas?
    Buffalo NY
    1,330
    Cracked fuel line perhaps?
    7
    Quote Originally Posted by zippogeek View Post
    That was my first thought. I blew into the line from exhaust to fuel tank which filled the fuel lines, to check for leaks, didn't find any.
    37
    try blowing the fuel to the engine through the exhaust line. This should get it started. It could be the seal around the fuel tank cap. First how did you try to prime the engine, over the exhaust or the carburetor intake?
    Woodward, OK
    494
    You could have a leak in the exhaust at the coupler, at the header, or your fuel cap could not be sealing. Did you change the piston and sleave, or the rod?
    sent from my not so smart, smart phone
    Rusty 2.5R,T-max 2.5 & 3.3,Summit VXL Nitro 4-tec
    7
    Quote Originally Posted by Rcracing6575 View Post
    Primed by finger on exhaust. Blew fuel through exhaust line, then battery died, so will try that.
    7
    Quote Originally Posted by westoakmech View Post
    I did replace piston and sleeve along with the piston rod. Ill double check header and exhaust
    1,994
    Maybe you need to crack the throttle a little bit. Sometimes the tiny passage through the lsn can plug up, so you may want to see if it will pull fuel with the slide open a bit.
    erbe emaxx 26maxx s27revo 18tmrevo XXL platinum
