Results 1 to 20 of 20
    west virginia
    91
    ERBE 2s or 3s???
    im getting back into the hobby after a 4 year break and im jumping right in with a erevo BE im sure that is has been asked a hundered times but im wanting to know which would be better for the out of the box stock truck the 2s or 3s (2 packs of coarse) im more than likely going to just run it where ever not real interested on high speed runs at this point im looking more for long lasting durability so thats why im asking. any comments or advise is appreciated and thanks in advance!
    so cal
    9,244
    Go 2s but go as big as you can! Spc has some 8200 batteries that fit and I would upgrade the drivetrain before running 3s. Shim the diffs would be on top of my list
    Most are out of stock but due at the end of the month http://spcracing.com/index.php?categ...3&show_all=yes
    37
    I would also suggest getting the castle link to tweak punch control and acceleration curves before going putting 3s into the truck, makes everything much more controllable with all the power.
    west virginia
    91
    my main thing right now is what batterys would be best i have be reading the forums for a few days now about twisted driveshafts and stripped diffs.... how long does this usually take to happen and im sure i will be adjusting the slipper and a few other things
    kansas
    7,807
    depends on how hard on the throttle & breaks you are........
    start with 2/2s geared for 21/54 low 50mph........
    slipper
    http://traxxas.com/forums/showthread...=1#post5388463
    links.
    http://traxxas.com/forums/showthread...=1#post5385157
    west virginia
    91
    well looks like im getting the erevo with the 2-3s included so what should i do first just to make it last a little longer?
    west virginia
    91
    sorry to seem like im a noob just want to be sure im doing things right been gone for a while
    Australia
    3,255
    I run 2/3s...tap into your esc with the CC Filed link programmer (sold separately) and set your punch, torque, brake and reverse settings. This is how I set mine...it will give you an idea on how to customise. I'm running 21/58 at the moment but if you heavy on the throttle with constant acceleration your motor will run hot.
    http://traxxas.com/forums/showthread...=1#post5308252.
    If you take it easy on the throttle and braking you should get some life out of you diff
    Rock n Rolla !
    Norfolk, va
    1,167
    I run mine on 2s with 21/40 gearing and it's quite difficult to drive on asphalt, wheelies or spins out when it hits full throttle.
    haven't had the opportunity to drive it off road anywhere since it's been so cold.
    ERBE, ERBE, Summit, Slash 4X4, Bandit,
    kansas
    7,807
    21/40 wow.... how close were you to get the gears to mesh?? had to almost be out of travle..
    Michigan
    81
    21/40! Do you have any heat issues?
    Don't try this at home!
    Australia
    3,255
    Quote Originally Posted by Zepher View Post
    Sounds like you running MOD1...correct??
    Rock n Rolla !
    Norfolk, va
    1,167
    Ya, Mod1 gearing. Does 50mph on 4S.
    495
    spc 8200mah 50c are in stock just ordered 4
    so cal
    9,244
    About time! Good price too!
    Norfolk, va
    1,167
    Quote Originally Posted by hottrodd1090 View Post
    Thanks, ordered a pair for myself.
    west virginia
    91
    What's suspension set up does everyone run for general bashing/ high speed runs? Just kinda curious to see what's out there and done a few things to the erbe
    Sent from my iPhone 5 using Tapatalk
    so cal
    9,244
    I run the long travel springs that came in the bag with the new revo front silver dot and rear blue dot with 80wt oil
    Works and handles great!
    Australia
    3,255
    I run 2/3s all the time...forever changing my gearing; it mixes it up for me. I also only use my eRevo as a dirt and grass basher now.
    I'm running Black F and Pink R with 60W shock oil at the moment...its working for me.
    http://traxxas.com/forums/showthread...6-ERBE-rebuild
    Rock n Rolla !
    west virginia
    91
    I've got free fronts with gold rears and stock oil been waiting on my mm to get back from castle it just came today first time it's ran in a month I've changed that bulkhead arm lock stinks to the bottom long wheel base arms and what it recommends to eliminate bump steer
