    11
    steering link on slayer
    Does anyone know the correct length of the steering link on the slayer pro 4x4?
    9,852
    You talking about the linkage between the servo and arm? Per the manual Page 34: 41.8mm.
    If you are talking about at the corners, I screw the end links all the way in and when the rest of the system is straight and the tires are straight I hook the links up and then adjust accordingly.
    11
    Ok I got the linkage to 41.8mm but now it wont reach from the servo to the arm. I upgraded my old slayer to the pro4x4 and I forgot to order the stock linkage so I went to a hobbytown usa and they didnt have the stock linkage so I got an aftermarket linkage. And when I set it to 41.8mm its too short. At this point I really dont know whats causing this problem.
    Tucson, AZ
    69
    I wouldn't really worry about exact lenght. +1 to Double G's post. 1) With your radio system on and servo centered, center the wheels and then adjust the linkage to a close fit. 2) Install linkage and 3) fine tune from there.
    11
    Ok thanks for the help.
