Results 1 to 12 of 12
Thread: Red light?
    32
    Red light?
    When I turn the car on the esc is green, then when I turn the controller on it turns to a barely lit flashing res color
    Putting the water on the hot stuff
    9,703
    Unplug the servo and see what happens.
    32
    Unplugged it and it works without it plugged in. Bad servo?
    Alma, MI
    12,281
    Yup. Quite common...
    I suggest upgrading.
    32
    To? Also what could I upgrade to motor/esc to?
    Alma, MI
    12,281
    What do you currently have?
    I have a BlueBird 390... cost about $30, all metal gears, 98%+ drop in.
    32
    Stock 302 Boss rally Vxl
    Venilion motor
    32
    I'm looking for fastest. Don't really care about snapping shafts. Just dont know what to upgrade to or anything.
    Alma, MI
    12,281
    Absolute fastest motor is going to be a Neu... 50togo has experimented with a few.
    MMP is the ESC he used, I believe.
    so cal
    9,244
    With the neu motor you have big block power in the size of a small block and the motor and esc will run cool!
    How fast do you want to go!
    I run the neu 1110 1/y and mmp esc. Takes a few mods to get it running you will need to shorten the shaft and grind a slot for the pinion screw to sit but you would be happy with the power and handling. Nothing else really compares http://www.espritmodel.com/neu-1110-...es-motors.aspx
    32
    Well I'm looking for more of a plug and play, but I will keep that into consideration.
    An off topic question, buddy of mine has the same car and his esc went out. What would be a cheap replacement that would work with the stock motor
    Alma, MI
    12,281
