Results 1 to 19 of 19
    49
    Slip, Slip, Slipping!!!!!
    How tight should that slipper clutch be? I have done the let it cool, quarter turn, 4 times already! Wont even wheelie rightnow its so loose.
    Buffalo NY
    1,330
    What batteries are you running? I had to switch to 4S LiPo to get wheelies; stock NiMh wouldn't do it. Whooeee!! The thing flipped right over b/c I didn't have the wheelie bar on...
    I tightened my slipper all the way down, then backed it off 1/2. Seems to be the sweet spot for me.
    49
    11.1v 3s. I tightened it and it flips over like yours now.
    Buffalo NY
    1,330
    Good to hear it! Now you have to learn throttle control!
    I was running the 11.1 packs for a while, but found the truck too uncontrollable.
    Enjoy.
    49
    Uncontrollable, I agree. Esp coming from a 3906 on NIMH!
    9,245
    i usually back off only 1/4 turn on the slipper
    49
    You tighten all the way then back off as well?
    9,245
    Yes. Only way to do it!
    Now that I am running trenchers I loosened it up a bit to save the diffs
    49
    I find with the Phaltlines, the tires spin on takeoff if I nail it. So I think with the slipper set where it is, I should be fine.
    9,245
    If you don't hear it slip for a second its too tight. Hard on the diffs when it spins and then hooks up
    delaware
    930
    you want it to slip alittle which slipper are you running
    9,245
    And I did mean when your tires spin and it hooks up. Not when the clutch slips and hooks up!
    Buffalo NY
    1,330
    I need to back mine off as well. Thanks for this.
    49
    I may have mines too tight, I will back off a half turn!
    9,245
    Never just back it off. I would tighten it then back it off. That way you will know where your at
    49
    How tight will it go? will it stop completely? I have it set to where the front tires come off the ground a few inches and thats it. Wont flip backwards or wheelie out of control.
    9,245
    No you just want to snug the nut not crazy tight then back it off
    Your sounds like its a bit loose unless your batteries aren't too strong
    49
    Batteries are brand new. I tightened it 1 half turn. It was slipping a little.
    9,245
    That should work! Anywhere from 1/4 turn to 1/2 is fine
    Wheelies depend on a lot of things.clutch adjustment and Tire size and esc settings to name a few
