Results 1 to 14 of 14
    Searcy, Arkansas
    48
    Anybody running wide axial beadlocks with rockcrushers or mudslingers?
    Would like to know how it looks before I buy some, really curious on the crushers. I know they need to be on narrow wheels, and will narrow mine if need be. Any pics would be appreciated!
    Victoria B.C Canada
    4,260
    I've seen the rock locs on wide rims didn't look right or perform as well.
    He narrowed the axials and they look and perform better.i ran the crushers on narrow rims didn't like them look good but don't perform very well depending on what you are doing.slingers are very popular and seem to work well.
    Sent using lipo power
    Mountains cant stop me
    they have tried
    Victoria B.C Canada
    4,260
    they have tried
    Central Texas
    18
    I am running the Axial eight spoke with mudslingers. I cut every other lug and star cut the foams. I feel they perform better than the Canyons on the rocks. The front wheels are weighted and the canyons were not so that might not be a fair comparison. As the slingers wear the grip seems to get better. The inner bead lock ring will rub on the front. I am now going to trim the rings thanks to the tip from German. Sorry no pictures.
    May 2009
    Edmonton, Alberta
    3,099
    Holy Bad Links Batman
    OP keep in mind that a few of the axial wide beadlock rims will rub pretty hardcore on the Revo/ERBE/Summit Front suspension arms and Front Turnbuckles
    KC
    310
    I was thinking about trying to bend the turnbuckles out of the way. I don't know if hub extenders would solve the rubbing problem.
    May 2009
    Edmonton, Alberta
    3,099
    A smaller inner ring would solve the problem, but they don't make one, and i haven't seen anyone else make one.
    I don't even think you would have to take an 1/8th of an inch off that inner radius of those rings and they would be fine.
    Don't bend your turnbuckles. that will just cause more issues.
    Extenders will only make it worse before it gets better. (if im thinking about that geometry correctly)
    Victoria B.C Canada
    4,260
    try that again strange they showed up on my phone ..... weird
    [IMG][/IMG]
    they have tried
    Searcy, Arkansas
    48
    I took my inner rings to a machine shop and they charged be a whole $8 to take an 1/8 of an inch off. Now they clear perfectly
    18v B&D summit
    You can NEVER go fast enough
    May 2009
    Edmonton, Alberta
    3,099
    Sweet, i knew that that was all it would take to clear.
    Chehalis, Wa
    422
    Quote Originally Posted by bad rat 55 View Post
    That's weird. I'm running ax8017 wheels and mud slingers and I took the inner ring off and they still rubbed with no extensions. I ended up taking 1 inch out of the center of the wheel to make it work.
    Before
    After
    _______^_
    /______l__\____
    l_l O l_____l O l
    Upstate NY
    83
    I now have 12mm offset but 3mm is all that was needed to clear the inner rings from the tierods on maximum steering lock.
    RC4WD Mudslingers with alternate lugs cut and glued to side
    [IMG][/IMG]
    Mounted on Axial 8 spoke beadlocks. Tires are stretched a bit due to the wide rim. Wish the Rocksters were still around.
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    Chehalis, Wa
    422
    How does the glued side Lugs box up? Have you ripped any off. I kinda like that idea.
    _______^_
    /______l__\____
    l_l O l_____l O l
    Searcy, Arkansas
    48
    Anybody tried the rock crushers on the wide beadlocks?
    18v B&D summit
