    1,458
    Howto remove steering assembly from the posts
    Hey,
    how do i remove the steering assembly from the posts to get to the lower bearing?
    Just tried but didn't work and I didn't want to force it.
    Is there are certain technique?
    Thanks!
    717
    You do have to put a little muscle into it, it will come apart
    RC Turnbuckle Jr. BaldyDaniels's Avatar
    Rouleau, aka "Dog River", Saskatchewan, Canada
    3,259
    Just make sure to remove the drag link and linkage first, then give a good pull.
    Sent from my iPad using Tapatalk HD
    Never trust an "Atom", they make up everything.
    Northeastern CT
    235
    You can use a pair on needle noose under the bearing (not on) to give you a little more surface area to pull on. Those guys can be on there pretty hard!
    Andrew
    Stampede 4x4 vxl w/ MMP/2400kv, Mini E-Revo
    Salisbury, NC
    633
    Quote Originally Posted by soundmaster View Post
    Hey,
    Thanks!
    Pry upward GENTLY with a thin flat bladed screwdriver, working all the way around each column a little bit at a time.
    The whole assembly will come off without removing anything but the two top screws. The bottom bearings will probably stay in place but you remove them the same way.
    1,458
    Thanks. I already managed it.
    Did it exactely the same way
    Salisbury, NC
    633
    I had to do it again Sunday to replace my front bulkhead and front dif case after hitting a telephone pole at 30+ mph in a jump gone bad! Servo saver did a **** of a job, as one wheel was cocked all the way over and jammed. Back up and running in about an hour. Thank God for the parts bin since LHS is closed from Saturday at 4 until Tuesday noon.
