Results 1 to 8 of 8
    143
    Accidently charged 2s LiPo on 3s setting. Help needed please.
    I accidently set my charger for 3s whilst charing my 2s LiPo, it now says over voltage whenever I try any charging options balance, discharge, normal etc
    I am using an Imax B6AC charger
    Would anybody be able to help me out?
    Thanks
    Alma, MI
    11,964
    What is the voltage?
    It needs to be lowered immediately... and safely.
    May 2009
    Edmonton, Alberta
    3,550
    It let you charge a 2s on 3s mode??? did you not have the balance tap connected?
    Alma, MI
    11,964
    Prime example as to why a "cooker" is not cheaper than a good charge system.
    143
    Im not to sure, I dont know how to check either
    how would I lower the voltage?
    Every other time its connected but I dont think it was this time
    Alma, MI
    11,964
    Check it with a multimeter:
    Does your charger have a discharge function?
    143
    No multimeter in the house
    Yes it does, if i plug it in it comes up with over voltage
    143
    I ran the battery in my ERBE as it wouldnt run in my Summit or Ken Block, the ESC would go green then flash red and turn off. But now when I put the batteries back in my Summit the ESC is solid green, I will go run the battery a little more and then balance charge it after.
