Results 1 to 10 of 10
    Lehi, Utah
    1,301
    Which motor to get?
    So I want to replace my stock motor, the 3500 brushless. I want to be able to get up to high speeds with out worrying about temps. What is a good motor to get? Don't care if I need to replace the esc. Also what does the kv mean? Is it better to have a higher or lower kv?
    Southern louisiana
    61
    I've been doing a lot of research for my self because I just replaced my motor. I'm not concerned about going super sonic so I went with the tenshock sc411 4000kv. But from all the reading in forums that I did prior to making my decision it sounds like you need the caslte creations 2400kv. A lot of guys say they can run 3s geared properly without over temping. I'd start looking at it then ask some more detailed questions about it here if you like what you read.
    Southern louisiana
    61
    http://www.brushlessrcmotor.com/brus...motor-ratings/
    This link will explain kv. I found it helpful. Also you can go to YouTube, type in what you want to know and there will be rc videos that are very informative. Good luck
    Feb 2010
    El Sobrante, Ca
    7,069
    Patrick is correct! I highly recommend the 2400 motor system! It is a great system that can be geared to run at a very high speed without getting hot. I have it in both of my trucks, look at my signature.
    Nashville, TN
    1,506
    +1 on the 2400. Get a mamba max pro or comparable ESC and turn the punch control up a little bit, or you'll be buying new driveshaft very quickly.
    711
    My vote goes for the 2400kv too. I now have that motor in 5 of my trucks.
    bakersfield ca
    149
    another vote for the 2400
    Drive it.Break it.ebuild it.
    Lafayette,LA.
    690
    Go 2400. 2s,3s&4s lipo. Crazy torque and speed. Can't go wrong with it.
    Sent from my MB886 using Tapatalk 2
    south texas
    153
    i concur with the rest of the pack. 2400kv is an all around beast of a motor! GEar high go fast no heat! ITs a win win!
    Slash 4x4 MM2 2400kv
    Lehi, Utah
    1,301
    That's for all the feedback. Sounds like I need a 2400. I think I'll look into castle. They have good products.
