Results 1 to 22 of 22
    Zeeland Michigan
    1,034
    Traxxas 3s 25c 5000Mah Cells not matched ?
    Like it says my 3s 25c 5000Mah cells are not right 1 cell 3.7 second cell 3.59 and the third is 3.71 . Was putting into storage mob everything was find when I ran it Yesterday 1/12 12.93v fully Charge , is it still safe to use ? Battery never got hot or warm and it's just over 4 months old . Thanks for any help .
    1 Rusty VXL + 1 Villain EX Boat
    St. Louis, MI
    8,156
    What was the charge state when you took these voltage readings?
    If it was after a run, the readings are acceptable.
    If it was after putting them into storage, not all chargers balance to storage voltage as storage voltage is not all that critical.
    Zeeland Michigan
    1,034
    OK , I just took reading All 11.0v first cell reading 3.71 then 3.62 and 3.73 . It put 3.6v per cell for storage . I'll hv to charge it to c how close they're .
    4,752
    Storage voltage is 3.80v per cell. 3.6 is low even 3.7 is for me. I do 3.8-3.85v
    DEU 8:18 ESV
    Zeeland Michigan
    1,034
    Do you think it is still safe to use ?
    Zeeland Michigan
    1,034
    OK, Just put full charge in it and hear it is All cell 12.4 v First cell 4.15 then 4.14 and 4.19
    St. Louis, MI
    8,156
    Balance charge?
    What charger?
    Zeeland Michigan
    1,034
    Hv a Onyx 245 and you can't charge a lipo without balancing . So evey time I charge I hv to balance charge and I charge it at 5 amps .
    St. Louis, MI
    8,156
    Are you sure the device you are using to measure the cells are accurate?
    It sounds like to me that the charger is not balancing them properly. If it were a dead cell the voltages would be wayy far off, not a few tenths.
    Zeeland Michigan
    1,034
    I just discharged it an stopping at 3.8v per cell and hears what I've . Total v 11.5 1fst c is 3.84 the 3.82 and last 3.85 . I've three diffident LVT's and they all whiten .01v . Jimmie do you think it's still good to use ? This is my second Lipo , My other is a SPC 3s 25c 5000mah as is the power cell the spc is with in .01 on all cells .
    St. Louis, MI
    8,156
    Call Traxxas... they have excellent customer support.
    Marshal Dadx2mj's Avatar
    Aug 2007
    So Cal
    19,721
    Situations like this is why I like having a stand alone balancer on hand. The one I have is extremely slow but when I have a pack out of balance at the end of a charge cycle I just put it on the stand alone balancer and let it sit until the cells are in balance.
    BlindMan Racing
    Rusty - MERV - Pede 4x4-QR-1
    SPC Lipo Power
    Zeeland Michigan
    1,034
    Called Traxxas support and he said try using TRAXXAS LIPO Power cell BATTERY CHARGER 2-cell 3-cell TRA..2935 . This way the charger charges each cell to bring the back to normal and if it don't work send in the battery . But he said it work on most of has battery's , So hv one coming Friday off ebay . Thanks for all the help . Also how far off balance before its no good ?
    Zeeland Michigan
    1,034
    Just got done recharging my battery with the balance charger and hear are the result's . Full charge 12.5 v fst cell 4.20 then 4.17v and last 4.20v . A lot closer than what it was . I'll check it in the morning to c if the second cell holds its charge before i put it in storage . Thanks for every ones help .
    St. Louis, MI
    8,156
    I would charge it with the Traxxas charger your next charge and check. If it keeps undercharging that middle cell it could be an issue with the cell.
    Zeeland Michigan
    1,034
    I did charge it with the TRA..2935 charger and it took almost 9 hrs .
    St. Louis, MI
    8,156
    It is a slow charger... I would still do it again after you run it at least one more time.
    Zeeland Michigan
    1,034
    OK , I'll drain it down two 3.9 per cell tomorrow the recharge it .
    St. Louis, MI
    8,156
    That should match it out.
    Zeeland Michigan
    1,034
    Well after sitting about 12 hrs . Total was 12.4v fst cell 4.19 then 4.09v then 4.18v . So that beaning said , looks like #2 cell is a bad cell any thoughts .
    St. Louis, MI
    8,156
    Probably...
    Zeeland Michigan
    1,034
    It hasn't dropped any more still reading 4.19 - 4.09 and 4.18 . ??????????? Not quite sure what to do with it .?????????????? Bin another 12 hrs .
