Results 1 to 13 of 13
Thread: Motor break in
    47
    Motor break in
    Hi, I'm a total newbie with electric.
    I've read on several threads about the motors have been broken in.
    Being delivered today is a new summit with the 8.4v nimh's.
    I plan on running nimh's for a while.
    What is the best steps for me to get the best life out of this motor?
    Cheers
    Jul 2012
    the middle of nowhere
    419
    Run it in low and slow for a couple sets of packs. Don't mash on the throttle.
    You can also elevate it on a coffee or paint can, set the throttle trim so it turns the wheels at a nice easy pace and busy yourself near by for 20 mins or so let everything cool and repeat.
    Basically you are shaping the brushes to the commutator for more efficient electrical flow.
    When a motor and brushes are new the brushes only contact the cummutator at its tangent point. After break in the brushes have the radius of the cummutator worn into them and therefore more contact area and efficiency. See my crappy illustration below...
    This is just a basic illustration but should help you get the jest of it.
    After break in pull the motor and clean with RC electric motor cleaner and lube the bushings at each end of the can with 3in1 oil or similar lube. Reinstall and go have fun.
    Sent from my iPhone using autocorrect
    Mount Airy, aka "Mayberry" North Carolina
    347
    CongratulationsDrive it reasonably for the first couple of rounds of packs. No full throttle takeoffs and reverse wheelies. Take this time to familiarize yourself with the controls and features. There are several theories for getting max performance and/or max life from the 775. This seems the most popular. It's also most like the break-in procedure in the manual, read it
    The Kid
    14.4 Dewalt & Misc. el-cheapo mods
    347
    +1 happy, a picture is worth 1k words
    The Kid
    1,148
    My first couple of packs i ran at light throttle around the back yard.. Give your summit a once over before you run it. On mine the steering was off center due to one servo being adjusted way to long this also created the servo's fighting each other. Also my speed control was not set properly i could only get 1/2 throttle out of it.. The only way i could get things to program again is i had to do a reset on the remote and then reprogram speed controller. Then i had to turn on servo reversing since i did a reset
    MN
    138
    So just curious, is the reason people use the water method to break in their motors because the water removes the debri (like the material from the brushes) and keeps it circulating instead of just building up elsewhere in the motor and causing problems and reducing the life of the motor?? This is my theory anyway, but I am new to this and have read oodles of posts on breaking in/not breaking in motors.
    47
    Thanks for the replies fella's, it's much appreciated
    She's all charged and ready to go, I've had a little drive around my living room lol (and over the kids)
    I'm curious to here this water break in method?
    So Cal
    408
    I dont understand any this. It'd not a gas motor. WFO baby, they last forever and are cheap to replce
    1,148
    Quote Originally Posted by Piranha-z View Post
    That and it helps keep the motor cool while breaking in. When i was into RC's 20 years ago i used to do the water break in. While i did find it gave the motor more initial power i found i was going through a set of brushes pretty quick. They never used to last more than a week of daily use where without a break in i would gt a few weeks out of a set. Did not care at the time as i always kept about 5 sets of good brushes and only took minutes to swap where the titan motor is a throw away when its toast
    So I take it that's a no go on the old fashion water break in when I get my summit in next week?
    4
    I have broken in many many electric motors and have done everything from installing and driving it hard, to putting it in water. I have found the best way is to get a product called com drops, it is an electric motor break in fluid that is designed to help break in, and seat motor brushes, which can increase RPM, plus keep commutator clean during break in process. The water method works on the same principal as (eg. wet sanding with fine grit sandpaper) and allows the brushes to fully seat to match the shape of the commutator. In any case the water method is cheaper but with the com drops you do not have to remove the motor.
    Jul 2012
    419
    Quote Originally Posted by csmithoch View Post
    Wouldn't it still be advised to pull the motor and clean after break in though?
    Nov 2011
    KC
    310
    Every 775 I got, melted. I did a rigorous "water break in", a light "water break in" and a no "break in"(business as usual). They all failed in the same spot within a couple months, the brushes. I gave up on brushed motors. Brushless motors don't need broken in and don't have any brushes to fail...
    PM me for help converting your Summit to brushless
