    Exclamation Problem with Traxxas Rustler Electric
    I have this traxxas rustler (xl-5, titan 12t motor) since christmas. A few days ago, while using it, it stopped working, and doing whats in the video.
    What happened? what can i do to fix it?
    In the video you can see that wheels dont work, i pull the trigger and the motor seems to work in a bad way, maybe its the transmission, what do you think?
    Woodward, OK
    451
    I would say that you striped the spur gear, the pinion gear, or the pinion gear came loose on the motor shaft.
    T-maxx 3.3
    Rusty 2.5r
    Summit VXL
    Nitro 4-tec
    So what could i do to fix it?
    Rotterdam, Netherlands
    7,281
    Quote Originally Posted by glavallen View Post
    Remove the gear cover (remove the right rear wheel first) and see if everything is ok there (check the items westoakmech mentioned).
    Zeeland Michigan
    1,196
    Sounds like your mesh is off or you striped your spur gear . either way you'll hv to do what Petertje60 said .
    1 Rusty VXL
    30
    It could be since it is a brushed motor, that the brushes came up. That happened to mine when i pulled the trigger everything would spin but no the wheels, or it wouldn't even spin. I brought it in and Hobby-town told me how to fix it. That would be odd though cause it is relatively new, if you got it for Christmas.
    RuStLeRaU
    Zeeland Michigan
    1,196
    That the brushes came up.This makes no seance if the brushes aren't on the motor shaft it wound not run ....................
    1 Rusty VXL
