Results 1 to 9 of 9
    309
    I picked up this 302 Mustang Boss Cheap on Craigslist With all intentions of making it a summit in the beginning All it said was it was not working And had no charger but as cheap as I got it I did not ask questions and sent my wife to pick it up. When she got there it was a kid and his mom. When she got home I could not believe it. The pic will show what i found that's why I'm saying a rebuild not just converting it
    1st off it had 2 different servos in it
    Then after looking at it closely I got the big shocker every metal moving joint on the rc looked like this
    It looks like red lock tight to me
    Well after I noticed that I decided that every piece will come apart front and rear differentials look good but the transmission was a different story
    After taking it all apart i Scrubs all the parts with dish soap and a toothbrush
    Alma, MI
    12,281
    Looks like they ran it wet and just left it that way.
    Gooberd up grease on the knuckles... blown bearing in the transmission... all that rust!!
    309
    this is the list of parts i have ordered so far
    Traxxas 7221 Chrome Roof Lightbar/Light-Bar
    Traxxas 7220 Exocage
    Traxxas 1/16 Mini Summit VXL TURNBUCKLES & PUSHRODS &ROCKERS
    Traxxas 1/16 Mini Summit VXL TRANSMISSION
    Traxxas 1/16 Mini Summit VXL *SUSPENSION A-ARMS & HINGE PINS
    Traxxas 1/16 Mini Summit VXL *BODY MOUNTS & POSTS*F&R
    Traxxas 1/16 Mini Summit VXL *AXLE CARRIERS & BEARINGS
    Traxxas 1/16 Mini Rally/Slash VXL 50T *SPUR SLIPPER/PINION/PLATE
    Some of the parts I ordered came in today Still not enough to get started
    And I figured since you restore completely apart I would dye some of the parts
    these wheels are not for the summit but i have like 5 sets so i just put a set in there to see how they would come out
    i put them back in the package
    Lincolnshire Il
    37
    Did you dye the chassis? that would look sweet if you put that in the 1/16 grave digger
    Traxxas ruslter, 1/16 modded grave digger,
    309
    yes i did it cane out good it dont look it in pics but it did
    got all the parts i ordered in to day !
    Just a set of wheels I had laying around I would run them for now but I only have 2
    Got my drive shaft today there's little bit of difference between the Mustang and the e-revo shaft
    309
    i put my slash wheels on it to test it out
    Hey bud, I'm looking into doing the same, converting my boss to a summit! I'm a little confused about the gear ratio, would I
    Have to mess with it? Also, would u be able to provide an itemized list of parts to do the conversion? U can email if u like to respond directly. Thank you for ur time hope to hear from u.
    Erik
    Does the drive shaft have to be swapped out from the boss 302 shaft to summit shaft or could u use what u got in the boss?
    Alma, MI
    12,281
    The drive shafts are the same.
    The axle shafts are not. The Boss ones will not work. I suggest getting stock 1/16th Revo shafts.
