    SW arkansas
    33
    Slipper Clutch Problems
    I built my revo several months back and have had the bugs worked out for a while, i put a picco .26 on it and had no problems till now. for some reason the slipper clutch will not grab anymore. started when i went to slayer gears in the trans. i put a brand new slipper setup on it and it lasted almost a full tank of fuel and then it started slipping and won't grab at all. any suggestions?
    Oct 2012
    90
    why u put slayer gears in it? does that basically lower ur gear ratio??
    revo 3.3 tmaxx 3.3 ofna hyper 7
    Tanker 822
    9,407
    The pads may be glazed so you would need to clean them up. You could do the E-Revo slipper upgrade or use the T-Maxx classic brake pad (with the hexagon center) as a slipper clutch pad.
