Results 1 to 11 of 11
    Asheville, NC
    144
    Question summit servo.. 1 or 2?
    should i have 1 stock servo, two stock servos, or one non-stock servo? I am hesitant to put in a new non-stock servo because i dont want to do a lot of trimming and drilling. Are there any servos that i can put in that will easily fit?
    11,145
    There are direct fit servos from Hitec, savox and bluebird... others also. They require NO trimming but WILL require a new servo horn I believe.
    2 stock servos is better than one and it will stay waterproof. But a single aftermarket servo with more torque and steel gears is definitely better than 2 stock servos.
    Pede, Summit,
    ERBE, Rally,
    Motley Crew, 1SQ
    Alma, MI
    12,280
    I agree with pav... here is a little more info:
    The Bluebird 390 is nearly a 100% drop in... and extremely easy to waterproof.
    To waterproof mine I pulled it apart (4 screws) put a gob of grease around the servo horn and smeared a little RTV on the seams as I reassembled. Took less than 10 minutes.
    Here is how to install:
    BlueBird 390 Set Up
    All stock hardware is used.
    NONE of the hardware included is needed!
    There are tab braces that do not allow the servo guard to sit flush.
    IT IS OPTIONAL TO REMOVE THEM.
    I have done this both ways without any adverse reactions.
    Here is a picture of the braces:
    (thanks goes to danielhr77 for the picture)
    The tab braces create a small gap between the chassis and the servo guard.
    Here is how it plugs in:
    You will also need to reverse the servo direction.
    These are the steps for LINK and TQi radios:
    Hold MENU for 3 seconds
    Green Blinks
    Press MENU
    2 Green Blinks
    Press SET
    Green Blinks
    Press SET
    Red Blinks
    Press SET
    8 Green Blinks
    Hold MENU
    Setup Complete
    Asheville, NC
    144
    thanks. i was also looking at the HS-85 (with Losi crawler arm ) which one do you think is better?
    Alma, MI
    12,280
    85 is analog... you might have issues with an analog servo in a digital radio system. Some do, some don't.
    5085 is the digital equivalent.
    6 in one hand, half dozen in another... which ever you pick is going to be the right choice. lol
    93
    I was also looking at this issue. So would I need 2 390 servos or are you recommending 1 390 to replace the 2 stocks?
    Alma, MI
    12,280
    1 390 is enough to turn most any tire that works well with this platform.
    San Diego, CA
    85
    What about the Hyperion Atlas DH16 servo? Its listed as having 166 oz of torque at 7.4 V
    Summit; ERBE; E-Slayer; MERVs
    Wraith; AX10; RX10
    Alma, MI
    12,280
    To run it at that high of a voltage you would need a separate power system... a BEC.
    Dimensions:
    32mm vs stock 30.5mm
    16mm vs stock 14mm
    31.6mm vs stock 27.9mm
    Dual mounting holes vs stock single mounting holes
    The 166in-oz is listed as holding torque; 83 as dynamic.
    It may work, but to run at that voltage is going to require more equipment on your RC and some modifications to get it bolted in.
    http://www.hyperion-world.com/produc...ct/HP-DH16-FMD
    Alberta Canada
    895
    I just ordered a Blue bird
    BMS-390DMH High Performance Digital Servo (Extra Strong) 5.4kg / .11sec / 22.5g
    Specification:
    Weight: 22.5 grams / 0.79 oz.
    Dimensions: 29 x 13 x 30 mm / 1.14 x 0.51 x 1.18 inch
    Torque @ 4.8V: 4.6 kg/cm , 64 oz/in
    Torque @ 6.0V: 5.4 kg/cm , 75 oz/in
    Speed @ 4.8V: 0.14sec / 60 deg at no load
    Speed @ 6.0V: 0.11sec / 60 deg at no load
    I also have a Hitec 5085. I'll compare both servos, one will be in my summit and the other in the Erevo. both trucks will have dirt hawgs.
    9,244
    I have both and both work great! The 5085 is quicker and stronger then the 85 not just digital
