Results 1 to 34 of 34
    162
    18v Dewalt, w/ MME m, 6s
    Howdy Summit brothers and sisters!
    My 18v Dewalt drill motor died the other day. I crushed the handle by dropping it 20 ft.
    I've removed, and cleaned the motor and soldered some thick wire to the motor tabs. I plan on using 6.5 bullet connectors and hooking the 18v Dewalt to my spare Mamba Monster Extreme ESC. (It has the castle cap pack on it). I plan on running the motor ESC combo on two 3s 45c 4500 mah lipos.
    I have a motor plate from kershaw designs that should work for the motor.
    There will be picture s to come. I intrested on peoples thoughts about he 18v Dewalt. I could nt find any threads using the google to show people using an 18v Dewalt with a mamba ESC.
    Wish me luck gentlemen.
    Victoria B.C Canada
    5,185
    The 18 v is the lowest kv of the dewalts(1800 kv or so iirc
    And will benifit from 6s.on 4s it would've under volted and be somewhat underwhelming.should have lots of torque
    Sent using lipo power
    Mountains cant stop me
    they have tried
    3,092
    A DeWalt drill died? With an eager summit owner and a "spare" MMM laying around? How convenient! Personally I suspect foul play, sacrificial murder for the sake of your sumit.
    But on 6s that thing should be a torque monster. Speeds still wont be crazy but it should have enough torque and power to gear it up. Please keep us posted
    MAN, Use Common Sense.
    Outside? THERE IS NO BOX !
    86
    Hahahaha. At the guy above.
    Perth, Western Australia
    56
    Mamba Monster Extreme ESC - Brushless
    Dewalt 18v Motor - Brushed
    Am I missing something?
    Jayson
    Summit BL HW SC8 2000kV
    E-Revo MM2 2200kV
    Newcastle, Australia
    965
    im with this guy ^
    162
    It's a brushed motor, I'm going to set the esc to brushed mode.
    Sent from my ADR6350 using Tapatalk 2
    Land o' flat.....
    1,121
    It looks like its just a Mamba Monster ESC with a bank of capacitors. As far as I know a Mamba Monster CANT run a brushed motor. Someone please correct me if Im wrong.
    Slash MT, 1/10 Summit.
    162
    Ha! It's alive! Better pictures to come.
    http://www.youtube.com/watch?v=O9fYj7wUSKQ
    Land o' flat.....
    1,121
    You might be able to get it to work, but you might burn out motors quickly.
    Toronto
    414
    Do you have a Field link to put it in brushed mode?
    Maybe it's a good idea to get replacement brushes if that 18v dewalt allows
    Looking at wot from the vid seems like it'll wear faster than usual
    12,290
    Check this out:
    http://www.castlecreations.com/suppo...s_ed_guide.pdf
    "Instruction manual for all Castle Creations Car and Truck Brushless Power Systems"
    Page 10 starts the instructions on how to hook the ESC to a brushed motor.
    162
    Thanks for information mr jimmy! Those are the directions I followed.
    I wanted reverse as an option, so I ignored the forward only extreme mode wiring. Wiring straight to the battery, seems crazy.
    Im definitely ordering more brushes! Holly cow, the sparks. Tomorrow, I will remove the stock pinion and mount the motor on the truck.
    Daddy kins I already set it to brushed mode with my link card.
    Victoria B.C Canada
    5,185
    When I put new brushes on my 14.4 just a while ago(same brushes).i did a 15 minute break in on my Icharger (dry).cleaned and lubed.
    First run it ate battery life(pre 8200s)
    Fair bit of sparks.another 15 minute break in (dry) much better no sparks good contact.runtime improved thats on 4s
    6s must be like fire works.lol
    they have tried
    3,092
    Quote Originally Posted by summitbasher420 View Post
    You are hereby officially corrected
    Oct 2010
    Parsippany, NJ
    752
    VERY interest in some action videos!!! Havent seen a combo like this yet.
    Oct 2010
    Parsippany, NJ
    752
    Just watched your motor test. I like the flame thrower you added to the motor. I once ran my Stampede with the Titan on a 3s. Ran like a bat outta heck and had the same sparks. Only did it once so I am curious to see how long the motor lasts.
    162
    I installed the motor today. Needless to say I'm not happy with the install, i apparently threw away my stock motor mount, so i decided to use an old Kershaw Design motor mount from my previous dual 700HO install. It took a lot of cutting to get the motor to even mount, and they way i cut the motor mount only allows me to use an 18 tooth pinion and 65t spur. I have no articulation on the motor so i can't change spur, or pinion size. I will be ordering a new mount from Kershaw Designs, so i can experiment with the best type of spur/pinion options.
    Pros/Cons ATM
    Positives:
    1) Torque, Torque, Torque. I couldn't stop the wheels once locked from turning with my hands.
    2) The motor doesn't tick, chug, glitch. No matter how slow you go. It's very responsive. Would be great for trail runs, and hill climbs.
    3) Loves 6s.
    Cons/Fear:
    1) It's slow, maybe too slow, and the added Torque is wasted compared to the Torque that it's higher KV brothers can put out.
    2) I think i Liked my Traxxas Big Block motor better!
    3,092
    i was able to run a 24t pinion on a 12volt dewalt before it burned up. im pretty sure you can go to a 20 or 22t for safe speed,
    162
    I need some help Traxxas community. Ignoring of sanity, what is the HIGHEST gearing one can do with 32p gears.
    The highest I've found is a 34t pinion and 50t spur. To be honest... i want more. (AGAIN, ignoring sanity).
    my 25t pinion and 54T spur with the 18v dewalt motor doesn't even get warm... and it's not fast enough.
    Victoria B.C Canada
    5,185
    Quote Originally Posted by DogMilk View Post
    That's a good sized jump in gearing.
    What kind of speed do you have now?
    And how(revo)fast are looking to go
    they have tried
    162
    This is not about how fast i want to go, it's about what an 18v dewalt can do I'm going to do more testing with my 25/50 set up, to be certain it's happy performing with that gearing.
    Then i want to go as far as i can go. Using the google, i couldn't find anyone that had used the 18v dewalt motor, and i figured i couldn't be the ONLY one on the internet that wanting to know what it could do with 6s power.
    I just want to make sure if I'm going to the extreme, I'm going the most extreme i can go.
    3,092
    PUSH IT
    PUSH IT
    PUSH IT
    But be certain to please provide us with some stats . Strap a GPS'd cell phone to it and give us some top speeds with each gear you bolt on.
    3,092
    Here is a gear calculating website (you may have been there) but it allows you to theorize the outcomes of specific gears. It even has sliders which would show you when your motor has reached its max.
    http://scriptasylum.com/rc_speed/car_setup.html
    Victoria B.C Canada
    5,185
    I'm in no way saying don't do it
    Just wasn't sure.
    they have tried
    162
    Small update, I found a website that sells custom gears.
    They have mod .8, 5mm bore pinions from, 12T all the way to 120T!!!
    Amazing! I ordered a 35 T, 40T and 52T! In stainless steel!
    Soooo excited.
    162
    Update!!! My gears are in!
    36T, 40T, 48T, 56T all in stainless steal!!!
    The smallest pinion in the photo is a 25t traxxas pinion.
    3,092
    Ok now which gears are actually gonna fit?
    I imagine that 56t would fit with a 20t spur. Now you have to find custom small spurs. I think the 3.3 revo had a 36t spur as an option.
    162
    Well I'm using the kershaw designs motor plate, but right the 40t and lower fits on my 52t spur.
    Im going to take the motor plate of and cut the motor slot arc longer. I'm confident ill be able to.run 56T pinion with a 50t spur.
    3,092
    any results? I was waiting to see "the fastest brushed summit ever"
    Oct 2010
    Parsippany, NJ
    752
    im with noir. dogmilk, did ur project fall thru or just on hold.
    some peeps here are good with math. guys,....what kind of speed can be expected with this set up? assume a 5.5" tire, right? anything taller would prob not be stable enough to get up to speed.
    Upstate NY
    83
    IIRC 18v is 1125kv, 14.4v is 1325kv, and 12v is 1525kv. I have tried them all and finally went bl. 18v on 6s is only 4-5k faster rpms than a 4s 14.4. Yes there is more torque to gear higher but it's not enough for the speeds you sound like you want to achieve. It also isn't the same "seat of your pants" feeling as more rpms are. Honestly IMHO your best option for speed is a BL motor. You can get a 2000+ kV bl motor for $50+ and there's no nodding necessary. You On GPS my summit will run 40 mph on 4s with a tekin rx8 2000kV motor with big joes by running stock spur and a 20tooth pinion. That is the largest you can fit without modding the motor plate and/or heatsink mounting or changing the spur.
    Best of luck with your quest for speed!
    162
    Howdy everyone, the project isnt over, but its changed.
    I burnt up the 18v with the 50t pinion... i had it geared, 50t pinion/58 spur.
    I did a couple of runs up and down my block, it was fast but obviously not as fast as a brushless system.
    The motor lasted about 20mins and smoked.
    Now im running dual 14.4 dewalts, and installed the kershaw designs aluminum chassis. Im going for pulling power. Im building a cart to pull.
    Ill post pictures tonight.
    Oct 2010
    Parsippany, NJ
    752
    What?? You didn't get it on video? No radar gun or GPS speed? We've been waiting since January DM Talk about anti-climactic....lol
