Results 1 to 11 of 11
    396
    Lower LVC in Cold Weather?
    I have my LVC set at 3.2v on my Xerun 150A powered Maxx, but my charger says ~3.7v when I plug into the balancer. I know this is normal; batteries don't run as long in cold. However, this esc is the first programmable one I've owned (just VXL's before) I was wondering if it would be a good/bad idea to lower the LVC to 3.0 (theoretically leaving cells at 3.5v resting) or lower? Thanks!
    9,244
    Have you double checked the voltage with a volt meter?
    I would have it set at 3.4!
    396
    Both my balance chargers say the same voltage, so I know its accurate. You have to remember that the weather I'm running in is approx 14*F (which really sucks, can't wait for summer lol), and any warmth generated by the batteries is sucked away by the snow-caked chassis.
    I'll bump it to 3.4 in summer like you said, but any advice for winter running? Should I keep it where it is?
    delaware
    937
    because you charger only see the rested voltage not voltage under load
    396
    Quote Originally Posted by 4sdash View Post
    I know that, however 3.7v resting voltage isn't fully discharged (should be around 3.4-3.5 ish) I was asking if lowering it would be safe in this situation.
    4,840
    I wouldn't lower it I have the 120 wp hw ESC. I have mine for 3.4v and stops at 3.6v which is OK. Under load it stops your lipos which is a good thing because if you lower it anymore your going to dip the lipo voltage too far.
    DEU 8:18 ESV
    Alma, MI
    12,282
    Quote Originally Posted by zball94 View Post
    You may know that, but I don't think you are understanding what he is getting at.
    Under load, the batteries are at least hitting LVC... 3.2. They could even be dipping below that... don't forget that you do NOT want your LiPo's to dip below 3v/cell under load.
    Cold is very hard on LiPo... it stresses them out and they don't perform the best.
    Burley idaho
    161
    I agree with jimmy when you punch the throttle the battery is putting alot of power out and when it is at say 3.5v per cell then it may dip to your lcv and it will shutoff. Maybe set your lvc higher so when it does get these high power discharges it doesnt dip below the 3v range. This is oly the way that i understand lipos so dont dog me if im wrong
    4,840
    In short that's what in was trying to say what Jimmie said. Also respect your lipos they will last longer and so will your truck
    DEU 8:18 ESV
    396
    Ok that makes sense. I didn't know they'd be damaged so much from going under 3v under load. Thanks!
    9,244
    Really isn't recommended but unless the battery voltage is pretty low under load drop below 3v would be very quick and would not do damage. I have recorded runs that dip that low but it was in milliseconds and did no damage
