Results 1 to 18 of 18
    127
    very bad crash.....
    Slash VXL 2WD.
    Just went for a short bash, don’t know how but I managed to heat a fence, not high speed but fast enough to crash the front left end.
    Lots of broken parts.
    Beside the front caster block and bearing carrier, what are the other damaged parts name ?
    Thanks.
    575
    Broke the front gray bulkhead also. Not sure what that fiberglass strip is called. Check out the exploded parts list on this website.
    South Jersey
    696
    Quote Originally Posted by mudrunner View Post
    Slash VXL 2WD.
    Thanks.
    http://traxxas.com/explodedviews/580...Qi-24GHz-radio
    Anza Slash & a pile of Parts
    127
    cool !
    thanks
    South Jersey
    696
    cool !
    thanks
    that shows you everything just click on the numbers it will tell you what is broke then you can get your list together and get at your LHS or other
    Michigan
    5,228
    They should have most of that in stock,don't you think?You might want to upgrade to an aluminum bulkhead thou.
    What better time than now.
    Grassie Ontario Canada
    3,136
    Your shock cap don't look the best.
    The other parts i see are the bulkhead and tie bar
    Jan 2007
    1,549
    Looks lime you need a hinge pin that goes through the bearing carrier, too.
    Lafayette,LA.
    693
    +1 on the aluminum front bulkhead. Money well spent and it can take a beating and a crash lol. My alloy bulkhead survived a head on collision with a speed limit sign. Good luck with your repairs.
    Sent from Oser world
    Lansing, Mi
    357
    Yea the aluminum bulkhead is my next purchase . I'm on my 3rd bulkhead at 6 bux a pop. Looking at the pic this is a great time to pick up sume caster blocks and a strc pin set.
    Does anybody know if you still run the tie bar on an aluminum bulkhead. I don't kow why you would.
    South Jersey
    696
    Quote Originally Posted by geeves View Post
    Yea the aluminum bulkhead is my next purchase . I'm on my 3rd buikhead at 6 bux a pop.
    that and the aluminum tie bar front end will be almost indestructible
    Jun 2010
    Springfield, Ma.
    3,359
    Wow, I've never snapped a tie bar before! Never seen one snapped either. Good job, now the fun part..... upgrades!
    Planet Vegeta
    651
    Quote Originally Posted by cbrsilv15 View Post
    caster block is the name
    Lafayette,LA.
    693
    I don't use one with my alloy bulkhead. Don't see how it would be needed once you go alloy.
    Sent from my MB886 using Tapatalk 2
    575
    Castor block is the black "C" shaped plastic piece. I was talking about the fiberglass piece right behind the bumper.
    Looks like a arm, fiberglass tie bar, suspension pins, c block, front bulkhead and possibly front knuckle. Time for rpm parts!! That's about the extent of the damage on my last wreck.
    575
    tulsa ok
    47
    your fence must of had a cement retaining wall.some nice breakage
    drive it like you own it,full throttle
    127
    Well, after that very bad crash, my slash got a full spa treatment…
    I've replaced all the broken parts + few screws and pins that where rusted or bent (the impact of the crash on internal parts is amazing) and basically all the other parts where tested and tightened.
    Then I decided to do something I wanted to do for a long time…
    1/8 Big-Blocks wheels + 17mm hex adapters.
    I've installed this:
    And here it is:
    Had to trim a bit the front end, didn’t test it yet, too much rain and wind in the past week, maybe the weekend will be nicer.
