now i want to start to get allimunim parts but dose any one know any thing about the gear cogs i just bought part 4116 and4470 could i have one any thing dif ????????????????
The 4116 is a 16 tooth clutch bell. The stock one in 20. A 16 tooth will slow the top speed way down, and increase the bottom end, or torque alot. You may have a problem keeping the front end down, and may eat drive shafts. The 4470 is the stock 70 tooth spur gear.
T-maxx 3.3
Rusty 2.5r
Summit VXL
Nitro 4-tec
thanks sweet!!
thanks do they sell them and would u put it in
would be good on a small corse
Last edited by Double G; 01-02-2013 at 11:55 AM. Reason: merge, this would be a good case for using the "edit" button
I myself would not run the 16 tooth, but I run in pretty wide open spaces. I have a hard time keeping the front end down with a 20 tooth at times. I tuned the rear suspension and helped alot. The 16 would probably be ok on a short tight track, it should jump out of the hole if you can hook the tires up.
T-maxx 3.3
Rusty 2.5r
Summit VXL
Nitro 4-tec
