Results 1 to 32 of 32
    Newcastle, Australia
    324
    Common Parts to break on Traxxas Summit
    hey guys i have just recently gotten a new traxxas summit and i am wanting to put together a tool kit for it so i can fix on the run. are there any common parts to break that i should put on my list for my tool kit? replies would be great thanks
    May 2009
    Edmonton, Alberta
    3,109
    The only thing i have broken so far on mine was the front bumper mounting loop. Summits in stock form don't go fast enough to break anything, they just get scratched up from rolling back down the hills you couldn't quite get to the top of hahaha
    Kansas
    21
    i would be an extra set of steering push rods, my son hit something and bent one.
    13,469
    Some good backup parts:
    5655: Half shaft set, short (plastic parts only) (internal splined half shaft/ external splined half shaft/ rubber boot) (assembled with glued boot) (2 assemblies)
    5656: Half shaft set, long (plastic parts only) (internal splined half shaft/ external splined half shaft/ rubber boot) (assembled with glued boot) (2 assemblies)
    5352R: Rebuild kit (heavy duty), slipper clutch (steel disc/ aluminum friction pads (3)/ spring, Revo (1)/ spring, Maxx (1)/ 2x9.8mm pin/ 5x8mm MW/ 5.0mm NL (1)/ 4.0mm NL (1))
    158
    Boom! This stuff! And aluminum pads are the way to go! I love um!
    13,469
    Quote Originally Posted by DogMilk View Post
    I actually don't use them on my Summit, but I do on my Slash 4x4. On the big trucks (Summit and ERBE) I use a modded T-Maxx brake disk as a slipper disk:
    May 2009
    Edmonton, Alberta
    3,109
    how modded do you need to go? I just bought a pair of HR Double up Slipper kits. Was just about to buy some pads as well.
    13,469
    You need to ream out ever so slightly every other pair of holes around the circumference - or take an extra minute and do every hole.This allows the holes to fit on the small bumps/pins on the plate that usually hold the pads. BUT, the brake disk is thicker than the pads and may push the spur gear far enough out to contact the gear cover. I usually clearance the inside of cover with a Dremel sanding drum but one could conceivably let the spur cut its own clearancing path in the cover. Would be noisy for a little while.
    May 2009
    Edmonton, Alberta
    3,109
    ah ok, maybe ill just pick up some alum pads instead. i have spur cover clearance issues as it is with Mod1 anyways.
    13,469
    Tires can rip (repair with Super Glue), some people break bumper mounts, and it's always good to have an extra set of suspension arms. I have not broken any of these on my own Summit. My ERBE tells a whole different story.
    Chehalis, Wa
    422
    I also would get your self a set of bearings. And If you want to spend money maybe a micro servo (2065) gear set and drivelines.
    Tra5120 12x18 bearing
    Tra5117 6x12 bearing
    Tra5180 6x13 bearing
    Tra2064 gear set
    Tra5650 drivelines
    _______^_
    /______l__\____
    l_l O l_____l O l
    324
    thanks guys
    the middle of nowhere
    417
    I might add a screw set so in the case you do have to work on your summit out in the field and accidently lose one you'll have some spares.
    Check eBay chop shops they're fairly reasonable and if you find a set for/from a summit you'll have all you should need.
    Stay away from the junk stainless screws, they look cool but they're soft and bend/break
    Victoria B.C Canada
    4,280
    I suggest Tony's screws reasonable price for a summit set.
    Sent using lipo power
    Mountains cant stop me
    they have tried
    15
    I keep a set of front control arms a set of wheel bearings a set of the short and long driveshafts and the inner and outer parts to make one complete driveshaft.
    324
    thanks people
    83
    First thing I broke was the rear drive shift, and the front one was on the way out to. This happened about 1 week after I had it. So at least carry a spare rear one. I replaced mine with the traxxas steel ones then I twisted an axle up. So I'd carry some spares of those to.
    Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
    1,541
    Even though you can't swap in the field but if you happen to run across a cheaply priced diff buy it for later.
    proj 002: The Funky Gecko
    Man, Use Common Sense!!
    207
    Quote Originally Posted by bstromback2002 View Post
    Do u have those part numbers?
    207
    Quote Originally Posted by Keila72 View Post
    Tra2064 gear set
    Tra5650 drivelines
    Thank you for this info
    87
    nice. I just ordered my Summit. What tools will I need to work on it?
    324
    the summit comes with all the tools you will need to work on the majority of the car, so you dont really need to worry about tools bud
    Victoria B.C Canada
    4,280
    But you will want to invest in a set of hex drivers,trust me you will.
    1.5 mm 2.0 mm 2.5 mm covers almost every fastener on the truck
    they have tried
    May 2009
    Edmonton, Alberta
    3,109
    yep, a guy can only use those L-wrenches for so long before you snap.
    Set of hex drivers is a must.
    15
    Quote Originally Posted by his grace View Post
    5331 & 5332 for the front suspension arms
    5653, 5654, 5655 & 5656 for the driveshaft parts. The only other thing I have broke is the output on the rear differential to right rear wheel. I drive it like I stole it so I'm kinda suprised I have not broke more stuff.
    207
    Okay, here is the set I ordered:
    5x8x2.5 mm (1pc)
    5x11x4mm (14pcs)
    6x12x4mm (4pcs)
    6x13x5mm (4pcs)
    8x16x5mm (1pc)
    12x8x4mm (4pcs)
    Does that look right?
    87
    so the summit doesnt come with bearings?
    Riverton Utah, The Most Windy City in Utah!
    2,109
    Nope. The Summit comes with FULL bearings. Except the motor bushings, (They don't count anyway) every thing on the Summit has bearings. You need to keep spares because some times the seize up with rust.
    324
    thanks heaps for the replies i am thinking of getting a drive shaft set, a front and rear a-arm set, and a screw set should do me just fine. maybe some glue in case the tyres come off the rim
    324
    anything else to add?
    carencro la.
    9
    Front long travel arms , front a arms and half shaft , and a slipper clutch ive got a new summit and so far this is all that has broke there tough trucks
    260
    +1 on the extra tyres, drive shaft, slipper clutch and diff set.
    for the toolkit get some bearing grease (you can pack the bearings to give them a longer life and if you run in the wet a lot), motor cleaner (if stock/brushed), spray lube, rubber cement to repair tyres that sometimes get cut from sharp rocks, edges.
