Results 1 to 13 of 13
Thread: Cleaning my Max
    92
    Cleaning my Max
    My beautiful Emax 3908 is caked with mud. Any advice on the best way to clean it up without
    harming the electronics? Thanks
    Yakima, Washington
    1,422
    if it is really bad you could just remove the electronics and wash the rest with a hose and then use a towel to clean the electronics themselves
    9,244
    Yep. Mud pretty much only comes off with water!
    Watch the water getting into the wheels
    Yakima, Washington
    1,422
    just try not to get too much water in the bearings
    92
    Ok thanks. I know it was kind of a dumb question but was just looking for the fastest and easiest way to go about it
    Jun 2010
    Miami, Fl
    6,731
    I like to remove the electronics, spray the whole thing with degreaser, give it a good brush in the sink with tons of water, then clean, and oil the bearings.
    Cocoa Florida
    4,002
    Just pull the electronics off then hose it down.
    And when your bearings do give it up from the mud intrusion don't get ripped off at the LHS for them, get the at AvidRC.com, most are $1 each & at those prices I keep an extra set of bearings in my box.
    Look out for the tree/crunch!
    LiPo? Naw NITRO!!
    92
    Great thanks for the info. I was wondering about what to do when it's time to replace the bearings which I think is now. I've had my max almost 2 years and haven't done anything to it except replace broken parts
    Thanks for the info. Sounds good
    Quote Originally Posted by RC-Fan View Post
    I noticed that the ceramic metal bearings cost $5 vs the metal only bearings for 1$. Is it worth buying the the ceramic bearings?
    Cocoa Florida
    4,002
    Quote Originally Posted by kirwinjd View Post
    I have not bothered with the ceramic bearings, @$5 a pop that's 5 regular bearings I can buy, & just don't see them having a major advantage to the steel bearings for a basher & the steel bearings have held up very well for me so far.
    Maybe if I was a racer or looking for ultimate speed runs where every bit of friction reduction helps I could see using ceramics throughout but not for just bashing.
    Ceramic engine bearings I could see doing but not for the rest of the trucks bearings.
    LiPo? Naw NITRO!!
    Kansas
    537
    My truck took a great mud bath a few weeks ago. The mud was caked on so bad I had to take it completely apart. I usually soak what I can in a bucket and check the bearings while I'm at it. The last of my stock bearings finally ceased up. I planned ahead and bought Avid bearings for the axle carriers. I just went with the half sealed / rubber Avid bearings.
    9,244
    If you are going to get ceramics I would get boca yellow seals
    More of a I ran out of things to upgrade and want to spend some money!
    9,244
    Mud sticks pretty good! I try to avoid it whenever I can
    3,259
    I hose down if really muddy and then lube after with the likes of RP7 or WD40.
    Rock n Rolla !
