    Oct 2012
    central ma
    17
    2.4 ghz interference??
    ok so i bought an led light kit for my merv (with 2.4 ghz system) and after i installed it i went for a test drive but it seems that there was radio interference because the throttle was choppy. i would hold the trigger steady but the motor stops and starts and sputters could this be due to my led lights or could it be something else
    Slash 4x4 mostly stock, 1/16 e revo slightly moded
    Sep 2011
    Iowa City, Iowa, USA
    1,566
    esc? maybe you overloaded the bec in the speed control.
    1:16 Slash VXL
    Stampede 4x4 3800kv
    Rustler VXL
    Aug 2010
    Port orange, Florida
    568
    Just what jimdog said, you could try a 9volt battery to the led lights, or just unplug them and see if the problem remains, remember to have good batteries in the controller as well.
    Sent from my iPhone 5
    Alma, MI
    12,287
    LED's have practically no load. I doubt it is the LED's causing the issue.
    I would make sure that they are wired in correctly and nothing is loose...
    Oct 2012
    central ma
    17
    Well the lights are integrated into the radio system for reverse lights etc. and the problem does not appear when i disconect the system so im sure it is that i tried rebinding the controller but that didnt work i might swap in an old rx/tx and see if the problem continues thanks for the advice
    Sep 2011
    1,566
    let me know what you think of the setup when you get it working. im interested in getting leds too.
    1:16 Slash VXL
    Stampede 4x4 3800kv
    Rustler VXL
    Alma, MI
    12,287
    Sounds like there is something wrong with the LED system... probably the controller.
    I have heard of stand alone LVC's having the exact same effects with Traxxas ESC's... I wonder if this is what is happening; interference from the LED controller?
    Oct 2012
    central ma
    17
    Well i actually ended up switching the whole system to my slash i found that the leds were interfering with my castle speed controller on my merv so i tried it on my slash and seems to work fine so i guess it just didnt get along with the aftermarket esc
