Results 1 to 20 of 20
    12
    Help Needed with Slash VXL 2wd
    Hi guys,I am wanting help to answer a couple questions I have about the Slash VXL 2wd version, i have
    given Myself a budget of 200$. my questions are,
    I want to make my slash go as fast as 50 mph, to do so i would need a 3s Lipo 23/86 11.1V battery
    Would i need to change any gearing,if so is this mildly easy to do. i am a beginner with about 3 months
    of experience, i have yet to open up the motor.
    i am wanting a new stronger, maybe alloy chassis, as my chassis (Stock) has broken twice.
    http://www.integy.com/st_prod.html?p...9#.UNzEb2-umtY
    this is one of my choices, i dont know about anyone else out there, but this seems to be a good option?
    now, my last question, Swing arms , I want blue alloy ones, but i was wondering who makes the best,
    or if i should get certain ones.
    - Thanks for your time
    Matt
    P.S.
    bonus pictures of my Slash now,
    [IMG]C:\Users\Administrator\Desktop\DSC_0154.JPG[/IMG]
    [IMG]C:\Users\Administrator\Desktop\DSC_0151.JPG[/IMG]
    [IMG]C:\Users\Administrator\Desktop\DSC_0152.JPG[/IMG]
    [IMG]C:\Users\Administrator\Desktop\DSC_0153.JPG[/IMG]
    [IMG]C:\Users\Administrator\Desktop\DSC_0155.JPG[/IMG]
    [IMG]C:\Users\Administrator\Desktop\DSC_0157.JPG[/IMG]
    12
    sorry, looks like you will have to copy and paste the links.
    NJ
    59
    I put a 3s lipo on my rustler hit a patch of sand and stripped the idler gear in my transmission. The stock gearing for the slash is 23/86. If you plan on changing the gears you should only drive the truck on a hard surface like the street or parking lot or be prepared to fix a few things every now and then. I believe Traxxas recommends 31 tooth pinion gear and 76 spur gear. You'll be going well over 55+ mph.
    As for the images you'll need image hosting. There are a bunch of free websites out there. One of the popular sites is www.photobucket.com
    South Jersey
    352
    Quote Originally Posted by TheNitroGuy View Post
    thats what i run on my slash 31/76 this thing FLIES only did it to see how fast i could get it waiting in my ProLine suspension to come in then i will give it the test run i will let you know how fast i got it
    Revo 2.5, SlashVXL, Stampede, RC18T
    Grand Traverse Michigan
    1,907
    I'm assuming you have the vxl brush less?
    Mine With 32p 20-54 Robision gearing,3800kv 4 pole castle,the gps said 72mph.
    The repair bill's was $250+ to fix the carnage,It even bent the motor shaft.
    And it has the pro line suspension with 2.8 rims and pl street fighters,Took out both of them on the right side also.
    And imop If it says integrity,its junk.[IMG][/IMG]Have fun,I'll never do it again,50mph is fast enough for me.
    Build it Ford Tuff,Just Use Chevy Stuff!
    12
    how about axles along with the gears, i want 50mph+ for streets and tough sufaces but at least 40mph off-road on packed
    and soft dirt. i know i would need metal? axles
    61
    Broke your chassis twice? Ouch.
    I've got a 3S and VXL...only damage from the extra power is a melted clutch bearing support-my fault to run it too loose causing it excess heat.
    It has run the 3S 16 times thus far. I tried it on pavement and couldn't understand how one can control it at 50+ mph. I had issues with the truck blowing over as I neared the high speed.
    I think a gearing change and the 3S is all you need...good luck!
    1,907
    All three of my trucks run steel Tekno axle's,even the pl set up,Tekno makes longer steel shafts for that purposes.
    Quote Originally Posted by MaTT12121 View Post
    1,907
    Knoxville, TN
    592
    If you are wanting a better chassis check this out
    http://www.chuckworksrc.com/Slice_A4.5.php
    Northern Ohio
    778
    I wouldn't get aluminum a-arms. They can spell disaster in most situations. Once they bend, you can never bend them exactly into place. And when they do bend, the handling of your truck can turn for the worse. Get some good RPM plastic ones, if they break you can mail them in and they will replace it for free. I have an RPM rear bumper on my VXL and I haven't had a single breakage with it yet. I was amazed on how much more stiff the RPM one was as opposed to the stocker.
    Slash VXL-SPC 2s
    Rustler XL5
    Racer @ YRC Raceway
    1,907
    I cant believe it,i bought a slash on line and it has that exact chassis a nice 4 pole 3800kv,I bent the out put shaft,but new one coming,Robinson hardened 32p gears and clutch, With the pro line suspension plus lots more,for $230, Man that's got to be the best deal I ever git in my life.
    Knoxville, TN
    592
    You want your money back send it to me!!!
    12
    Thanks for all the answers, still haven't made my decision on a chassis. i have been looking for a bit and it doesnt look like
    there are that many out there
    12
    ok, i have a new problem. i cant seem to find the name of the part witch holds the front shock tower and connects to the
    front of the chassis underneath.also connects to the front A-arms please reply if you know the part name
    149
    I think you mean the bulkhead this thing
    1,907
    Thanks anyway i just got it back together after a nice wreck ,but didn't know what a deal i got,post #5 on this thread is a pic of it,just waiting for the castle motor rebuild kit.
    Knoxville, TN
    592
    Next time aim for the left side since you'll have spare a arms and the motor shaft doesn't stick out on that side. LOL
    1,907
    Wont be a next time lol.
    12
    thanks thats it!
