    Sep 2011
    Snellville, Georgia
    95
    Merv brushless upgrades
    So I'm always looking around for different upgrades and looking today at different brushless upgrades, tacon makes a 7800kv motor and I already own a hobby wing 60a esc if I were to run 25:50 gear ratio on 3s lipo how much more speed would I get then stock brushless geared and ran the same way? By the way the motor is TEN dollars.
    Pittsburgh
    765
    What Tacon motor is 7800kv that accepts 3s?
    Quote Originally Posted by Tacon
    code 96m01-car-2030-7800
    Net Weight (g) 50
    Watts 130
    Outer Diameter?mm) 20
    Length (mm) 30
    Stator 15MM
    No of cells (lipo) 2
    max efficiency (%) 85%-89%
    max efficiency current 18
    no load current (A)/7.4V 2.2
    Internal Resistance (mohm) 0.0325
    Shaft Diameter (mm) 2.00
    Shaft Length (mm) 10
    KV (RPM/VOLT) 7800
    Turns (for cars)Poles 12T/2POLES
    Max Voltage 8.4
    Wire Size 0.28
    Bullet Connectors YES
    Bullet Connector Size 3.5MM
    design for FSD
    0111001101101001011001110000110100001010
    Sep 2011
    Snellville, Georgia
    95
    Oh nvm how bout 2s on stock and tacon? Sorry just thought majority of motors could handle 3s
