Just placed my order at KD for a Dewalt motor and the center dog bone kit. Also ordered a couple of fans for than southern heat. Sent an email to SPC for some 8000mah 2s lipos when they become avaliable. Should be some good times ahead.
SUMMIT,EREVO
P4DE,MERV
I hope Kershaw Designs come through for you.
Other members have had issues getting their product and not having any response via email about the issue.
I had one issue with him. Then the next time everything went good. So hopefully it wont be an issue. I dont know where else to get the Dewalts from. Also those batteries are suppose to be in late tomorrow in stock.
SUMMIT,EREVO
P4DE,MERV
ebay has the dewalt motors.
Whats the right part # i need?
SUMMIT,EREVO
P4DE,MERV
This one is what I used.
Dewalt #396505-21 .
Avoid the one that has the four tabs it is more work to make it fit.
Sent using lipo power
Mountains cant stop me
they have tried
Thanks man. I really do appreciate it
Sent from my iPhone 4s 32g using Tapatalk
SUMMIT,EREVO
P4DE,MERV
I'm going to dbl check that just in case
Here is another source
ttp://mobile.robotmarketplace.com/BP396505-21.html
they have tried
So WHY is the Dewalt motor seemingly the go-to motor upgrade?
It is just a bit more robust.has replaceable brushes,also makes it easier to clean.can be over volted for more power.is able to handle a bit more aggressive gearing for a bit more speed.
they have tried
All for about the same price as a replacement 775!
I've had several orders with kershaw designs and never had a problem. KD always Replies to my emails as well.
Just thought id put my experience into the mix.
Parts arrived today! Very impressed!!!
SUMMIT,EREVO
P4DE,MERV
If it has connecters on the wires to attach to to brushes (spade connecters)....cut them off and solder the wires to the brushes.They have a bad habit of not lasting long in a rc enviroment.I would also recommend if you want to be able to remove the motor seperate from the esc get a decent set of 5.5 mm bullet connecters if none are included.
they have tried
Yeah my plans are to put new connectors on all the stuff and use solder.
SUMMIT,EREVO
P4DE,MERV
And here they are installed
SUMMIT,EREVO
P4DE,MERV
Nice. 10AWG is overkill, but nice overkill.![]()
Thanks. Lol. It's what I already had in stock
SUMMIT,EREVO
P4DE,MERV
Looks good. Better your wire be too big than too small.
Man I love the power of the Dewalt. It will hold crawling around waaaayyyy better than the Titan. I am definitely amazed.
SUMMIT,EREVO
P4DE,MERV
cool! I just got my SPC packs today and I took some photos for an unboxingSummit should be here on Thursday! No hobby shops around here but is there an electric cleaner and bushing lube I can use from my local hardware store?
Someone recommended some kind of lube in one of my threads. I'll have to go back and look.
SUMMIT,EREVO
P4DE,MERV
CorrosionX
SUMMIT,EREVO
P4DE,MERV
Motor cleaner for the motor. Or electrical parts / contact cleaner for the motor - make sure it is safe for plastics. Bushing / bearing oil or 3-in-1 oil for the bushings.
I like that fan mount for the EVX2... Id like one of those too.
Pede, Summit,
ERBE, Rally,
Motley Crew, 1SQ
The fan mount came from KD. After seeing it I feel confident I could build one. The fan of course started off as an esc fan for a Velineon system. Cut all tabs of any sort off and then just bolted it to the mount.
SUMMIT,EREVO
P4DE,MERV
i am looking on the KD website and I cant see were you can order the dewalt by itself. All i can see is there dual cradle with a single dewalt in it. Did you ask them specifically for just the dealt with 2.4Ghz radio adjustment as i cooked my second motor Titan motor.
Go to the brushed motor section of the products. It's in there with no mounts. I run a 2.4 with no caps. Did all the wiring and connectors myself.
SUMMIT,EREVO
P4DE,MERV
so when you mean no cap you mean no capacitor to be wired in just straight wiring from the motor to the ESC.
Can one of our radio guru's clarify this I read it somewhere and forgot about it .
If you run with or around others who are running am still.you should consider running caps.the dewalt is still spewing out "noise" that can interfere with am signals.
they have tried
I wouldn't consider myself a guru... but you are correct.
You cal always do what I did. Un solder the wires and xaos from the 775 and solder then on the dewalt motor.
_______^_
/______l__\____
l_l O l_____l O l
Kershaw sells them too,just for convenience if ordering something from there.
they have tried
Sounds like I should add caps myself....
SUMMIT,EREVO
P4DE,MERV
I need new ones....couple of "driver error" incidents. lol
Add cap (100nF) i think may want to check that
from
+ to can
- to can
+ to -
they have tried
Is it necessary to have a cap from one brush to the other. I have one from + to case and one from - to case.
_______^_
/______l__\____
l_l O l_____l O l
